who has blown there shocks?!?
Old Dec 4, 2002
KeNsHiN's Avatar
LEVA
who has blown there shocks?!? and what here you replaced them with?
Old Dec 4, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
I've been riding on eibach sportlines for about 7 months (9000 miles), and my shocks are fine. However, to answer your question about replacements, I believe the only aftermarket replacements right now are the Koni yellows. I think they run about $550 a set. Tokico is supposed to have shocks and struts out for our cars early next year.
Old Dec 4, 2002
djmota's Avatar
I've had blown rears for almost a year now. they blew about a month after I installed my ground controls and slammed it. Could'nt wait any longer for the tokicos so I just ordered a set of 4 Konis from tornactive. Bouncing gets old.
Chicks with big t!ts don't like to ride in my car any more
Old Dec 4, 2002
Bartkat's Avatar
I never had any blown shocks cause I put Konis on when I put on my springs.
But I did get a blow job from a fat chick once in the back seat and the shocks held up ok.
Old Dec 4, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
I have.. after only 15000km on stock springs. I replaced them under waranty...
POS car
K-lx
Old Dec 4, 2002
curt's Avatar
curt is an unknown quantity at this point
Same with me i had stock springs and blew my front pass. side shock. but got it replace under the warranty and then i put my coilovers on. I also waiting for the KYB OBX shocks and sturts to come out. or just go with a full coilover system, best way to go but a little $$$$
Old Dec 4, 2002
sumama's Avatar
sumama is an unknown quantity at this point
Quote
[hr]Originally posted by: Bartkat
But I did get a blow job from a fat chick once in the back seat and the shocks held up ok.[hr]
Blow jobs are cool, but from a fat chick?? [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Dec 4, 2002
sumama's Avatar
Can you tell whether you blow your shocks or not? I mean, will you definately notice it?
Old Dec 4, 2002
Bartkat's Avatar
Fat chicks are easy.
Old Dec 4, 2002
sumama's Avatar
Quote
Fat chicks are easy.[hr]
won't argue with that one
Old Dec 4, 2002
dragoon's Avatar
had my springs on for about 10 months, shocks haven't blown yet, waiting on tokicos or anything that's cheaper than the $550 konis.
Old Dec 5, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
i blew a front one with stock springs still, with like 5000miles on my car
Old Dec 5, 2002
flotsamm's Avatar
Is it me or does it sound like the only peeps who are blowing struts have a 2001 Civic? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 5, 2002
Guest
Guest
Posts: n/a
my rears just blew out last week... i have neuspeed springs
Old Dec 5, 2002
Vinh's Avatar
how do u know if u blew your stock springs??
i ordered a camber kit and now i'm about to order the ground control coilovers
and DIY installation with a 2" drop on stock shocks....
how will i knoe if i blow them and i thought u can still drive with blown shocks?
Old Dec 6, 2002
Bartkat's Avatar
Push down on one corner of your car several times and get it bouncing. If it bounces more than once after you stop pushing on it, the shock on that corner may be bad. With real good shocks the car should stop bouncing right away after you stop pushing it up and down.
Also if the seals are blown, there will be oil on the shock that has leaked from the inside to the outside. Often there will be lots of dirt stuck to the oil. That's what mostly happens when they blow, the seals go bad and the dampening oil leaks out. Then all you have is the tubes and pistons with some air inside.
Old Dec 6, 2002
ALPHSTER's Avatar
THE FIRST LETTER!
ALPHSTER has disabled reputation
While changing back to stock wheels for the northeast snow storm I saw the front pass blew [IMG]i/expressions/face-icon-small-mad.gif[/IMG] (Everything is oem). Sounds like a lot of us are having this problem???
Old Dec 9, 2002
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
I think my passenger side rear shocks are blown. I saw a puddle of oil under it.
Old Dec 9, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I've got the eibach pro-kit and I cant tell if they're blown or not.. it still feels really stuff, but the left rear has like no finger gap and my right rear has 1 finger gap and my car looks lopsided! Would a blown shock make the car lower on that side?
Old Dec 9, 2002
zetaR's Avatar
Hey IDQ, I'm not really sure what the difference is between a shock and a strut, if there is any? However, I used to have an 87 Ford Tempo (I know, pimpin ride [IMG]i/expressions/laugh2.gif[/IMG] ). It had a blown strut and the car leaned to the right. I also had a friend who had a truck with a blown strut and it leaned as well. Sounds like this could be your problem.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Dec 9, 2002
flotsamm's Avatar
I remember reading that the left side sits lower than the right due to it being heavier on that side. Some peeps notcie it, some dont. I noticed it the first week I have my coupe. A blown shock shouldnt affect the ride height, as the height set by the springs.
Old Dec 9, 2002
blouisgod's Avatar
Life Begins > 6800rpms
just blew my drivers side front yesterday with 10250 on an 01'. Getting two new fronts on Wed.
Old Dec 9, 2002
Bartkat's Avatar
Left front seems to be a problem on some 01's. I converted struts for a guy for Konis and he had a blown left stock strut. Then he told me the koni also blew. These were two different sets of strut housings too. There just seems to be a problem there that dealers should have a buletin for..
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
Bruce2
Sep 27, 2015 08:45 PM
