Progress or RSX sway bar?
Old Oct 28, 2002
Sarvic's Avatar
Sarvic is an unknown quantity at this point
Which do you guys think is the best sway bar out there for our cars?
[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Oct 29, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
i believe progress has the complete set, which of course is the best way to go...but $$$
RSX Type-S sway bar is nice, but only for the rear and its $82 shipped at HondaWerx.com
u decide[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 29, 2002
slikor's Avatar
slikor is an unknown quantity at this point
if i remember correctly, the Progress rear anti-sway bar for our cars is 22mm, whereas the RSX one is 19mm, so if you want a much stiffer anti-sway bar, the Progress one is better. I have the RSX rear anti-sway bar, and its friggin awesome, but now that i have front and rear tie bars all around and im getting Tein SS coilovers soon, i want to upgrade to 22mm in the rear, and perhaps the 27mm (i think Progress' front anti-sway bar for our cars is 27mm) front one from Progress.
note, i think that if the rest of your suspension is stock, and you got the 22mm rear anti-sway bar it wouldnt be as noticeable of a difference than with the kind of setup that i have, but it still would improve the handling greatly.
Old Oct 29, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
I have tried both the RSX Type S swaybar and have now installed the Progress unit. By far, the Progress swaybar makes a bigger difference. Reason being that the swaybar is supported by a brace that stiffens up the chassis mounting points and the bushings are made of polyurethane (stiffer). The RSX bar still utilizes rubber bushings and allows for more slop.
Even though the RSX set-up is cheaper, it's not nearly as effective as the Progress unit. Save some money and buy Progress. In addition, I would highly recommend purchasing the Polyurethane bushings from Neuspeed that have been designed to replace the front OEM swaybar bushings. Even with stock tires, this combination is absolutely "night and day" difference from stock (or even the RSX rear swaybar).
My current suspension set-up: Neuspeed Sport lowering springs (Coupe), Koni (front/rear), Neuspeed front swaybar bushings, Neuspeed Front Upper Strut Brace, Progress rear swaybar. So far I'm VERY pleased.
Terry
Old Oct 29, 2002
Sarvic's Avatar
How good is the Eibach Anit-Sway Bar?
Old Oct 29, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I've got the progress rear anti sway bar installed, read this thread I posted a while back....
http://www.7thgencivic.com/forum/mes...word1=PROGRESS
Old Oct 29, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
there is also the JDM type R bar that is 22mm and uses urethane bushings. cheaper than progress
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
