*a few pics from the tein install*
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
front
the stupid bearing that busted.. cost me my lunch for the whole week
front w/camber kit
my next mod ... a lift !!
back slammed
front slammed, well uhhmm .. not slammed.. i mean the lowest setting !!
my ricey stickah ..!!
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture021.jpg (29 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture023.jpg (26 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture024.jpg (23 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture025.jpg (32 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Picture027.jpg (34 Kb)
Old Oct 27, 2002
Gshockbreaker's Avatar
Gshockbreaker is an unknown quantity at this point
So, basically its... pulled the old strut/springs out and just pop in the TEINS with OEM bearings??
Old Oct 27, 2002
mohawkboom's Avatar
how much are they?
Old Oct 27, 2002
VNlilMAN's Avatar
The Standard One
what size tires do you have? looks like the front could only drop like 2" the most.
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: Gshockbreaker
So, basically its... pulled the old strut/springs out and just pop in the TEINS with OEM bearings??[hr]
basically yes.. but i didn't do it .. i brought it to the shop .. cuz i wanted to make sure that it was done the right way ..!
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: mohawkboom
how much are they?[hr]
i paid $1000 for the tein .. and i paid $150 for installation and another $50 for the bearings !
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: VNlilMAN
what size tires do you have? looks like the front could only drop like 2" the most.[hr]
205/40/17 ... yeah that perch is all the way down ... i talked to my mechanic and he said that I can purchase special springs that can replace the tein ss springs, if i wanted to drop the front more ..! he said that i would have to call tein usa to special order them and made to my cars specification .. ! i hope this is true .. cuz i'm gonna be purchasing them soon because i want my car lowered !!
Old Oct 28, 2002
TOOLOWCIVIC's Avatar
What shop installed them?
Old Oct 28, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Any strange noises coming from these coilovers?
By the way, how did that plastic bearing get so screwed up?
I've had my suspension apart a number of times but that bearing was always in perfect condition.
TJ
Old Oct 28, 2002
mohawkboom's Avatar
does it have a nice stiff sporty ride..or is a littlemore tame?..I'm looking for some very performance oriented coilvers or springs/koni setup..
Old Oct 28, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: TOOLOWCIVIC
What shop installed them?[hr]
carboy on bissonnet ..!!
Old Oct 28, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: 3rdcivic
TJ[hr]
there is a slight creaking noise coming from the rear, but this only happens if i put too much stress on the shocks (like going down a steep ramp or going over a big'ol speed bumps), but u can hardly hear it .. u can hear it if u turn u'r stereo off.
well i had goldline springs, but it was already cut when i bought it .. (bought it from a friend already used) .. and my front end before was like 4 in. off the ground .. so it was really really slammed .. u can barely put all five fingers between the front bumper and the ground .....
ps : my ride used to ride like a canoe on the rapids .. i swear .. i would always hit my dashboard, because i hated the ride on them 'ol springs ! ...its like 110% better right now !!
Old Oct 28, 2002
HCCriminal's Avatar
an0therpin0y
Quote
does it have a nice stiff sporty ride..or is a littlemore tame?..I'm looking for some very performance oriented coilvers or springs/koni setup..[hr]
this is the best investment so far ... ! it depends on you .. u can make it stiff if u want .. i have mine on the standard settings right now .. and it is perfect .. not bouncy and not too stiff ..! its just perfect .. i'm not scared to go over anything anymore ...! .. i rate these coilovers a 10
Old Oct 28, 2002
mohawkboom's Avatar
Spring wise...how's the body roll in tight curves and such?
Old Oct 28, 2002
HCCriminal's Avatar
an0therpin0y
it sticks to the ground like its part of it .. !! i was just driving home from school today and i took the shortcut which has a lot of curvy roads ..! it really feels good ..!!
Old Oct 28, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Quote
[hr]Originally posted by: dimsum
it sticks to the ground like its part of it .. !! i was just driving home from school today and i took the shortcut which has a lot of curvy roads ..! it really feels good ..!![hr]
The benefits of front wheel drive cars having a stiffer rear. It corrects the understeer and gives you a little oversteer. You should get a stiffer sway bar for the rear next and strut bars(if you do not have them already).
Old Oct 28, 2002
you didn't have to get OEM rubber washers??
Old Oct 29, 2002
HCCriminal's Avatar
an0therpin0y
Quote
you didn't have to get OEM rubber washers??[hr]
i did.. as u can see from the pic .. ! but they broke because my car was slammed ..![IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Oct 29, 2002
slikor's Avatar
slikor is an unknown quantity at this point
looks nice man, i hope to be installing my Tein's this weekend. btw, i ordered all new parts for the stuff you have to re-use like the rear dust cover and upper mount and the front mount and bearings etc. did your OEM washer break because of the Teins or because of your previous spring-based drop?
i plan to post a DIY of my install, with lots of pics and exact parts list of what parts you have to re-use and all that stuff. i'll also be installing an Ingalls rear camber kit and SPC front camber kit.
Old Oct 29, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: slikor
i plan to post a DIY of my install, with lots of pics and exact parts list of what parts you have to re-use and all that stuff. i'll also be installing an Ingalls rear camber kit and SPC front camber kit.[hr]
my washer broke, because of my old springs ..! i really don't think that u need the front camber kit ..! but i still installed em ..!
Old Oct 30, 2002
slikor's Avatar
ahh, ok, good i thought the washer broke cause of the Teins
well, it looks like the required OEM parts (the ones you have to re-use for the Teins) i ordered are gonna ship today, so they should be here on Friday, and the front and rear camber kits have already come, and the Teins are coming from TornActive on Thursday, and the Neuspeed front upper strut bar from TornActive is coming on friday too. on friday i plan to work from home so i can get started early since im sure it'll take several hours...hopefully by saturday i'll have a completely differently riding car[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
i'll post the pics and DIY shortly after...wish me luck[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Oct 31, 2002
HCCriminal's Avatar
an0therpin0y
Quote
i'll post the pics and DIY shortly after...wish me luck[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][hr]
good luck man .. and i got my tein from rob too ... !! he hooked us up bigtime .. that day that i bought my teins from him .. i was about to get it from someone else .. for like $117 more .. so i bought me an altezza grill .. with the money i saved ..!! ..... and hey .. will the neuspeed or any strut bar fit... my car eventhough i got a CAI .. it looks like its gonna be in the way [IMG]i/expressions/face-icon-small-confused.gif[/IMG] help me out on that ..! thanks
Old Oct 31, 2002
slikor's Avatar
thanks man, i hope it goes well esp since im gonna take a long trip (going to baltimore w/ my girlfriend to celebrate our 9month anniversary ) on saturday--the day after im doing the install--so i'll have very little time to fix things if i mess up[IMG]i/expressions/face-icon-small-wink.gif[/IMG] heh
yeah, the Neuspeed upper front strut-tower bar will fit just fine with any intake, it is really the least obtrusive on the engine bay of any intakes i've seen, and IMO looks the nicest (esp since you can get it in black so it really blends in).
btw, i wish to give mad props to Rob @ TornActive for being so damn awesome (and having such an awesome company with great prices, customer service, products, etc) i am so glad i was able to get this stuff through him, and i will absolutely not ever hesitate to give him my patronage many times in the future....now all it will take is money...[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 2, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
IMO tein is the best suspension out there, good choice[IMG]i/expressions/beer_yum.gif[/IMG]
Old Nov 2, 2002
VNlilMAN's Avatar
The Standard One
well tein doesnt have much competition right now... i think only other true coilovers are b&g. just wait till JIC comes out.
Old Nov 3, 2002
Hey slikor, you from Frederick MD?? I'm from Howard County MD But I'm in school right now all they way down in FL. I miss MD...
Old Nov 5, 2002
DIMO's Avatar
DIMO is an unknown quantity at this point
I have been waiting for the jic-magic coilovers to come out but I heard that they don't come with dust boots.
Old Nov 6, 2002
curt's Avatar
curt is an unknown quantity at this point
Hey i have a Injen CAI and I have DC strut bar so yeah it should fit.
Old Nov 6, 2002
curt's Avatar
Hey how much did they cost you(tein coilover set) and you said that you got them from tornactive and you got a deal through Rob, the reason why im asking is because i have a set of coilovers and now shocks cause of my $ but i just got a new job and i want a full coilover system and i found teins for like $1200. let me know thanx
GshockBreaker what area of HC are you from. I live in PG county. used to work in HC.
Old Nov 7, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: curt
GshockBreaker what area of HC are you from. I live in PG county. used to work in HC.[hr]
$999 for the teins ... from tornactive.com .. but there is a groupbuy right now on the groupbuy section .. and the teins are going for $9?? something .. i know its lower than what i paid for ..!!
