Neuspeed Front Sway Bar Bushing Kit - Opinions?
Old Aug 29, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I was thinking of getting this at some point. Has anyone tried them yet? Any noticiable benefit in responsiveness? Yey or nay?
http://www.neuspeed.com/pages/sway_bars.shtml
Old Aug 29, 2002
CapYoda's Avatar
Escaped Convict
I got it a long time ago but never found the time to put it on.
it would be a bit of a hassle of an install as I would have to jack up the car, remove the sway bar bushing or the entire sway bar... and the neuspeed bushing isn't cut, so I'll have to cut it myself to be able to use it...
I dont expect miracles, or to even be able to feel the difference... but suspension tunning adds up... it stiffens the sway bar some more... alone it wont be noticable, but with other modifications, you can definitely feel the difference.
Old Aug 29, 2002
slikor's Avatar
slikor is an unknown quantity at this point
i got this a while ago and installed it before i had my other suspension mods, and i think i noticed a little bit of a difference. it essentially locks the bar in position because these new bushings are polyurethane so there are no rubber bushings to squish and allow further movement.
it was very east to install them, and they did come precut (it is kinda hard to tell they're precut because unless you pull them apart with your hands the seam is almost invisible) and all i did was use a ratchet to remove the 4 bolts holding the sway bar bushings on, remove the stock bushings, grease the Neuspeed ones with the included synthetic bushing grease, and reinstall with the correct orientation. obviously, i had the car jacked up too, and on jack stands so it wouldnt fall on and kill me[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
i think that this mod with the RSX 19mm rear anti-sway bar, and some other suspension mods (like what i have) will make the best difference because all the little changes like the front polyurethane bushings, and the rear strut and tie bars, and larger low-profile wheels/tires, etc will combine to make the car noticeably nicer to drive and all around better handling. let alone if you drop the car or have coilovers....that'd probly make an even bigger diff.
Old Aug 29, 2002
CapYoda's Avatar
Escaped Convict
they come precut!??
I can't see it at all. geez.
Old Sep 3, 2002
I order some. They should get here in 7-10 days. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
I'm gonna be doing a bunch of suspension mods in the next couple weeks. B&G coilovers this week, bushings next week, RSX sway bar whenever, Neuspeed rear tie bar whenever they come out with it. Hopefully I'll have enough 'play time' between mods so I can tell if any individual mods make a difference.
Old Oct 14, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
if you just get the neuspeed front sway bar and completely replace the stock, does it already come with neuspeed bushings installed in it?
Old Oct 14, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
yes i think so. but those bushings should be different then the ones u can buy individually because the neuspeed bar is thicker then the stock.
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
