Koni knocking
Old Aug 19, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Koni knocking
My shop called Koni about this... They first thought it was the springs.
Apparently the bolt on the bottom of the front shocks come loose or off easily.
If you hear knocking sounds when driving slow or doing slow turns, check those bolts. Would be a good idea to weld them on too. Don't think it'd be catastrophic if they come off, but still dangerous...
Old Aug 19, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
it's really the bolts, i dont have koni's i have h&r's springs and they knock only when i turn it to the left, like a "pop" could this be due to it twisting the spring??? This is what spain tires told me that the reason it happens is because the spring is twisting, it doenst happen at high speeds tho, only 5mph or parked
Old Aug 21, 2002
Bartkat's Avatar
If the Koni bolts are properly torqued, they aren't going to come loose. I've got over 5000 miles on mine and have checked them twice, and they still have the original torque.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Styven Szastur
Sep 23, 2015 05:26 PM
curaze
Sep 22, 2015 08:27 AM
