lowering?
Old Aug 14, 2002
civicvtec1ps's Avatar
Search and Learn
yes get rear camber kit . you dont really need front . but its only about 25 bucks for front camber kit
Old Aug 14, 2002
SatansEnemy's Avatar
SatansEnemy is an unknown quantity at this point
thanks and i noticed i put that in the wrong forum
Old Aug 15, 2002
JoeyTStyleS's Avatar
JoeyTStyleS is an unknown quantity at this point
how come u dont need front??
Old Aug 15, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You most certainly need the front kit. And besides at 25 bucks it is hardly worth a set of tires.
I don't mean to rant, but there is always a right way and a wrong way. The right way is to use one set of the widely available kits to correct the camber. Using them guarantees your car will be aligned properly. Without them, you simply cannot do it and accept it if it is off.
You may get lucky and your car will not be out of specs and not need one. But that is probably rare and only if you lower it only about an inch. Just factor it into the cost of doing business and do it right. NOTHING looks more rice than to see a Civic going down the road with the outside of the tires barely touching...
Old Aug 15, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
are they expensive to install, or easy to do yourself?
Old Aug 15, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: rickinthescv
You may get lucky and your car will not be out of specs and not need one. But that is probably rare and only if you lower it only about an inch. Just factor it into the cost of doing business and do it right. NOTHING looks more rice than to see a Civic going down the road with the outside of the tires barely touching...[hr]
actually you dont really need the front as we have mcpherson struts and the camber is hardly effected. 2cute has explained this very well last time. even with a 3" drop the front will probably still be in spec. but yes $20 isnt a big investment.
as for the rear, someone posted their alignment spec sheet after lowering their car with eibach sportlines and it showed that even with the drop, everything was in spec. i think you really should get one for a drop thats lower then 2". a 1.75" drop is debatable.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
