do i need to cut the rubber bumpstop more???HELP!
Old Jul 20, 2002
Royando's Avatar
Royando is an unknown quantity at this point
Ok so like i installed my springs (goldline)about 3 days ago...its all good. no noises..but now its like everytime i hit something (lil bump on the road) i hear this one noise, like something is hitting on both sides of my front suspension. it something to do with the struts i know that, all im wondering if i need to cut them both more..it says that im suppose to cut like..1.25 in the front...but i think i only cut like .75 I THINK...i didnt really measure it... yeah i know that was stupid of me. so is that what you guys called bottom them out? or something like that? does anyone know how much to cut from the front?( talking about the lil black rubber that is on the bar of the strut), ok so im like new at this..please help out.
peace out yo! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 20, 2002
Machina's Avatar
Machina is an unknown quantity at this point
where did you cut it...if you didn't have 2 pieces after you cut it, then you might have cut the wrong part of it...
Old Jul 20, 2002
VNlilMAN's Avatar
The Standard One
i have neuspeed sports and didn't cut the front, only the back
Old Jul 20, 2002
Royando's Avatar
ok i got a picture now n stuff...i know that it tells you to cut like 1.25" but i prolly cut too much..is there such thing as cutting off too much? or i probably cut the wrong thing. i just cut the ..well..you can take a look...heres a pic..please help.. cuz i hate the sound that it makes..sounds like a clunk ..(little one) but you can hear it. sounds like my struts are bottoming...i know they are still good cuz i have a perfect ride..its just that sound..((((???))))
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] bumpstop2.jpg (24 Kb)
Old Jul 20, 2002
VNlilMAN's Avatar
The Standard One
you have a better chance of bottoming out with full bumpstops then no bumpstops cause cutting/removing the bumpstops gives more shock travel. however removing them gives you a higher risk of blowing them.
Old Jul 20, 2002
Royando's Avatar
so is what im hearing when i got like lil bumps that they are bottoming??? or ?? ...i know my shocks are still good..so what you are telling me that i did it right, but.. what i need to do now is cut like more of it?? or what? i just hate the sound when i go any lil crack on the road, it sounds like im driving a model T that is falling appart.
anyways...what do you think i should do?...
Old Jul 20, 2002
VNlilMAN's Avatar
The Standard One
i have no idea what to do... does the noise sound like somethings loose or does it sound like a 'thud' like when you go over a speed bump too fast and hit the bottom of your car? cause my car sounds like somethings loose. its most likely cause the springs arent sitting right... if it is this kinda sounds i guess try spraying wd-40 on the top/lower perch cause some have said that that works...
Old Jul 21, 2002
Royando's Avatar
it sounds like something is lose, but i just hate how it sounds,, i mean if it was like semi big bumps it be cool but..its any lil crack on the road..i think imma cut more the rubber things, just like 1/2 inch more or so. i know imma be buying new shocks (aftermarket) anyways..so..i just hate it..its not like big thug sound, but like the springs are lose..or something...or the inside of the shock is hitting on something
Old Jul 21, 2002
VNlilMAN's Avatar
The Standard One
i dont think cutting the bumpstops more is going to solve your problem, since its over little cracks i'm 99% sure its not your bump stops...
Old Jul 21, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
i didn't even cut my bumbstops ride is good just dont drive like a madman and be observant to the road......
Old Jul 21, 2002
Royando's Avatar
alright so im going to take a look later today...and its not that i hear it in almost every single little crack but when i hit little obstacles on the road..for example..the reflectors that the city uses to devide the lanes...something like that..or somewhat dips that are in the road..and so on.
alright..we'll see what happens
Old Jul 21, 2002
Royando's Avatar
ok guys...dont take me for a stupid guy but..i think thats what i am or something...i took off one of my rims and then like tried to push up and down the strut..and..i found out what the problem was..the nut that holds the shock at the top was kinda lose and that is what made the noise...
thanx for all the advise though. i think what happened is that when the springs settled made the shock lil lose,i just needed to readjust it..
peace out [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
dlg1985
Jul 23, 2017 10:03 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Mc7602
Sep 17, 2015 02:01 PM
Klame9420
Sep 7, 2015 10:03 PM
