2002 Civic SI - Front suspension
Old Oct 27, 2024
Philip54's Avatar
Philip54 is an unknown quantity at this point
Is it possible in the 2002 Civic SI to replace the lower ball joints without removing the knuckles from the car?
Thanks
Old Oct 29, 2024
BrotatoChip's Avatar
Super Moderator
Re: 2002 Civic SI - Front suspension
Yes, but why? You still have to remove the axle. You're then forced to use one of those large C clamp things instead of a shop press.
Old Oct 29, 2024
Philip54's Avatar
Thanks for your reply. I realize that the axle still needs to be removed to make room for the C Clamp, but is better than having to remove also the knuckle.
Old Oct 29, 2024
Super Moderator
It's not that much more work to remove the knuckle. Remove the caliper (without opening the brake system), remove the WSS (or unplug/unbolt from the chassis and bring it along), remove the two bolts holding the knuckle to the strut.
Less likely to mess up the alignment leaving the knuckle in but easier to replace the ball joint with the knuckle out. Pick your poison.
Old Oct 29, 2024
Philip54's Avatar
Thanks for your clarification. I understand the trade-off between the two options.
zhek18
Nov 27, 2009 11:23 PM
zhek18
Nov 26, 2009 06:19 PM
shortync269
Jan 8, 2009 10:05 AM
thelatinpimp
Jun 18, 2007 08:52 PM
TonnyHegger
Apr 19, 2002 11:05 PM
