Bilstein Shocks on LX trim
Old May 27, 2021
Theturrettop's Avatar
Theturrettop is an unknown quantity at this point
Hey so I'm looking at the Bilstein shocks, specifically the BILSTEIN 24114240 model number, and wanted to know if they will fit on the LX trim as well. I am aware that they go on the SI but I was curious if anyone tried them with an LX or non-SI model. I imagine that the biggest concern would be the springs possibly not fitting correctly.
Old May 27, 2021
FRSam's Avatar
Click Here
Re: Bilstein Shocks on LX trim
RockAuto shows the same part numbers so it appears so. I'm assuming you mean the American Si (DOHC engine, hatchback), not the Canadian one that is physically similar to the LX.
Old May 27, 2021
yeah, just the American on. I actually got an email that Bilstein claims they do not make the shocks for the non - SI of that year. If that's the case, if the manufacture doesn't recommend it. I won't go for it.
Old May 27, 2021
from the top of my head, tierod ends, i think crush bolts were different
Old May 28, 2021
BrotatoChip's Avatar
Super Moderator
Model year matters here. All years of the Si used 16mm crash bolts, only '03-'05 of the LX would also use 16mm. '01-'02 used smaller 14mm bolts. Even with that difference you can get an adapter to work. Everything else should be the same.
Toasterstrudel
Jan 5, 2022 06:46 AM
sivlercivic02cc
Apr 18, 2005 03:16 PM
prccivic
Mar 29, 2005 01:04 PM
reelbigfishc22
Oct 23, 2003 08:32 AM
7thGenLX
Sep 7, 2003 05:45 PM
