4 lug to 5 lug conversion
Old Apr 12, 2021
Bobo6's Avatar
Bobo6 is an unknown quantity at this point
So does anyone know about the conversion? Ive read rsx swap but i know the 04 civic si is basically the same but instead of 4 lug it has 5 lug which would be easier? And is anyone familiar with the process btw i have an 03 civic si
Old Apr 12, 2021
Colin42's Avatar
Re: 4 lug to 5 lug conversion
There's a sticky........
https://www.civicforums.com/forums/4...1-01-05-a.html
Old Apr 13, 2021
Bobo6's Avatar
Originally Posted by Colin42
hey bro i appreciate the look out ive actually seen that but it seems like a lot of bs have you seen a forum for using the 04 to an 03 ep3 swap on the wheel hub? You would think that it would swap right out without all the extra stuff
Old Apr 13, 2021
try to fit then...
Old Apr 13, 2021
Bobo6's Avatar
Damn i would love to try it if i could afford a mess up lol i know i cant be the only to have thought of this. Has anyome else tried?
Old Apr 13, 2021
the ones on the link most likely tried and still recommend swapping the who rear suspension
The ones that actually write articles to help others usually don't ask questions, they go and try it
Old Apr 14, 2021
BrotatoChip's Avatar
Super Moderator
I know I tried swapping just the read hubs from a '03 RSX to a '03 EP3 and it didn't work. It's been ~5 years so I can't remember why. RSX and '04-'05 EP3 use the same rear hubs I believe so I don't think it will work.
Old Apr 14, 2021
Bobo6's Avatar
im sure its because the rsx pretty much had a rhicker suspension and its acura i understand thats honda but its the upper class honda lol they use same base but a lil better so thats why if you swap the hubs you might aswell swap the suspension but im inly guessing i really dont know
Old Apr 20, 2021
Bobo6's Avatar
4 to 5 lug conversion
Has anyone tried an adapter? Is it worth going that route?
Old Apr 20, 2021
duplicate, merging with previous thread
Old Apr 20, 2021
Super Moderator
An adapter is also going to add an offset, you'd have to make sure your wheels would fit properly. In my opinion I wouldn't use adapters. If you want to go 5 lug so bad do it properly.
Old May 5, 2021
Super Moderator
Re: Suspension
Originally Posted by Bobo6
I want to see if i can swap the wheel hub from an 04 ep3 si but indont know if i can do that i dont even know hiw to go about checking that lol but thays the plan so far
You have to swap the whole knuckle, front and rear. Wheel bearings are different sizes.
Old May 5, 2021
Bobo6's Avatar
Re: Suspension
So if i swap out the knuckles for 04/05 ep3 all i need then is the wheel hub assembly aswell and it should be good? That would be way cheaper than doing the rsx stuff i keep reading about.
Old May 5, 2021
moved 4 to 5 lug discussion from your suspension thread.
it fits better here.
Old May 5, 2021
Super Moderator
Re: Suspension
Yes. '04-'05 EP3 uses the same knuckles/hubs as base model RSX. RSX type S has larger front brakes and axle which is why some choose to use them. Cheapest option here is to just find a 4 lug wheel.
Old May 5, 2021
or find a 04-05 car
Old May 5, 2021
Bobo6's Avatar
Damn i was hoping i could just swap the **** because i dont know how an adapter would do. Any ideas on an adapter? Or does anyone onow where to find some badass 17 in red 4 lug wheels?
Old May 5, 2021
just get the wheels painted.
CivicJR22
May 22, 2009 03:27 PM
SleakCivic02
Feb 21, 2006 07:50 PM
Si2NV
Ottawa
Dec 5, 2005 10:15 AM
civicrider01
Engine Swaps
Apr 12, 2005 12:26 PM
rijowysock
Mar 13, 2004 09:55 PM
