Skunk2 lowering springs
Old Feb 13, 2020
Zjcal's Avatar
Zjcal is an unknown quantity at this point
I just had Skunk2 lowering springs installed in my civic ex. In the description it says there is a 2.25” drop in the front and a 2” drop in the rear, but my front end is clearly higher than the rear. I do have the fatter springs in the front and the skinnier ones in the back, so I know at least that part was right. Do they just need to settle or do I need to fix something?
Old Feb 14, 2020
Colin42's Avatar
Re: Skunk2 lowering springs
Probably just need to settle
Old Feb 14, 2020
GolNat's Avatar
Prelude Owner
Yeah they should settle some but springs for the 7th gen sometimes leave the rear lower.
Old Feb 14, 2020
Zjcal's Avatar
I sent an email to skunk2 about it, but how long do they normally take to settle? And does it just happen naturally or should I try to hit like shallow potholes or speed bumps?
Old Feb 14, 2020
Colin42's Avatar
Train tracks and speed bumps will help, you don't have a bunch of heavy stuff in the trunk right?
Old Feb 14, 2020
GolNat's Avatar
Prelude Owner
Technically they all should settle together so the difference won't change between front and back. You can add a spacer in the rear to bump it up a bit.
Old Feb 14, 2020
Zjcal's Avatar
just a sub and a spare tire
Old Feb 14, 2020
Zjcal's Avatar
I originally had spacers on all 4 but when I put the springs in they couldn’t fit in the back so I have spacers in the front but not the back
Old Feb 14, 2020
GolNat's Avatar
Prelude Owner
Take them out.
Old Feb 15, 2020
Colin42's Avatar
Ok just wanted to make sure you didn't have like 400lbs of tools or something in the back
Korupted
Jul 23, 2011 01:50 PM
Armin
16
Aug 8, 2004 09:16 AM
Amontalvo
Apr 12, 2003 07:36 PM
Purple2001Civic
South
Apr 5, 2002 06:51 AM
