Suspension options for 05 Civic Si
Old Dec 9, 2016
9000revs's Avatar
9000revs is an unknown quantity at this point
Folks, what is a good spring/shock combo for mild drop (< 2") that would be suitable for some daily driver and 1/2 HPDE days a year?
Thanks.
Old Dec 9, 2016
Re: Suspension options for 05 Civic Si
eibach works well on the regular civics, not sure on the hatch
koni or KYB (upper range) does wonders
Old Dec 11, 2016
9000revs's Avatar
I am looking at Eibach Prokit and Konis, but confused by the two options on TR.
http://www.tirerack.com/suspension/S...5&autoModClar=
Anyone know which Konis are the right part? Also, for such a mild drop, ~ 1", is there need of a camber kit? If so, what do you recommend? Thanks.
Old Dec 12, 2016
i ran autoX without the camber kits, and the lack of front camber, plus the rear getting into the -1.5 made the car extremely understeering in autoX tight cornerings.
ended up damaging my 2nd gear synchros (excessive wheel spin for 2 years autoX).
correcting the rear camber was a lot more important than getting more front camber.
since correcting the rear camber, car rotates much happier (-1.5 front, -0.5 rear), no front anti-roll bar and progress rear anti-roll bar the car is much happier to turn.
the hatch is a little tail happier than the coupe, so maybe keep stock front anti-roll bar? not sure about the rear bar that would work.
Old Dec 12, 2016
you could look into Max's suspension setup too, although he also have an coupe like me
https://www.civicforums.com/forums/4...sion-swap.html
he stops by every once in a while if you want to PM him.
