03 Civic EX Coupe Lifting Info
Old Dec 13, 2015
Kristoco's Avatar
Kristoco is an unknown quantity at this point
Have been reading quite a bit about the things one needs to lower their civic yet I want to lift mine by 3-4 inches as I live in Maine and not all roads are flat or tar. I am also new to the Honda world though I've always wanted one.
I am looking for any info that can keep my budget low yet do the job correctly and keep a nice smooth ride as it has now.
Thank you,
Kristoco
Old Dec 13, 2015
GolNat's Avatar
Prelude Owner
Re: 03 Civic EX Coupe Lifting Info
Buy a truck.
You are going to need to do custom suspension work to raise it that high. A set of coilovers can actually allow you to raise the car a bit but not 3-4 inches. Maybe 1-1.5. You have McPherson struts in the front and struts in the rear so you will need a shock with a long piston rod or sleeves that allow you to raise the whole assembly up.
Old Jan 6, 2016
lowlife9's Avatar
putting bigger tires on would be your only option for
lifting the car without suspension mods. but you won't get much higher before the tires start to rub.
fatih717171
Jul 25, 2016 06:22 PM
JKWood
Jul 28, 2015 03:45 PM
civicPRODIGY
Nov 28, 2001 08:24 PM
civicdude
Brakes
Nov 21, 2001 08:00 PM
se7en
Nov 12, 2001 10:13 AM
