Where to start modding/upgrading suspension
Old Aug 8, 2013
2001CivicDx's Avatar
2001CivicDx is an unknown quantity at this point
So I bought an 01 DX coupe. The previous owner's exboyfriend lowered her civic, but she didn't like it and got it brought back up. So I'm not really sure what happened to the suspension. Anyways, out of personal interest, I kind of want to do some work on the suspension. I'm not sure where to start because I'm a total noob at this, so can someone give me some ideas?
Also, what do you think happened to the suspension? The car, at least the front, still looks a little lower than stock, thanks guys!
Old Aug 8, 2013
Poopies's Avatar
Super Moderator
Re: Where to start modding/upgrading suspension
Sounds like the ex installed some lowering springs, but the previous owner put the stock ones back on. Probably because the ride was rougher or something.
On a civic suspension assembly you have your shock absorbers and the spring that goes around them. You can buy each one separately (i.e. Tokico Blues and Neuspeed sport springs) or you can get some coilovers, which combine the two. Coilovers are adjustable but generally more expensive, so it all depends on what your goal is. Do you want to trade ground clearance for performance (not to mention looks) and slam your car to the ground, or do you just want a nice little drop with the increase in handling?
Unfortunately, with suspension price tends to matter. A $600+ setup will generally outperform/outlast a cheap set of house brand coilovers at Autozone.
There are quite a few discussions about the best struts/shocks+springs vs coilovers here, so enjoy the hunt!
Old Aug 8, 2013
lowlife9's Avatar
couldn't really tell you without seeing pics of your springs. as for were to start since you have the dx there's no rear sway bar i would purchase a progress rear sway tie bar kit and there sway bar adapter kit http://www.corsportusa.com/store/cat...roducts_id=324
http://www.corsportusa.com/store/cat...ducts_id=21859
as for suspension either Koni yellows with Ground Control springs or progress technology cs http://www.corsportusa.com/store/cat...roducts_id=481
Old Aug 9, 2013
what is said above.
nother setup is the eibach springs (sport or pro) and tokiko blues. they work well from what i hear. i use the eibach pro + kayaba and always liked them.
you can always read the links in my sig too :P
Old Aug 9, 2013
CGaud's Avatar
CGaud is an unknown quantity at this point
My 3 favorite mods on my car:
#1 Sway Bar (less body roll and handling improved)
#2 Coilovers (looks better but ride comfort was reduced)
#3 Short Shifter (shift throw reduced and "sportier feel")
hans.pcguy
May 16, 2015 09:54 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
