ground control install
Old Mar 11, 2013
samgodbout's Avatar
samgodbout is an unknown quantity at this point
Hi !
I just bought my set of grouund control with koni yellow
for the rear, it was esay to install, the sleeve sit on the snap-ring of the koni yellow.
for the front, it's another story
do you know if I need to put the sleeve directly in the bottom in the stock insert ?
I dont see other way to put the sleeve.
but all the weight off the car wil sit directly ont the thread of the sleeve and I don't know if it's strong enought.
Thank you soo much !
Old Mar 12, 2013
sl33pyriceboi's Avatar
Re: ground control install
you will insert the koni yellow tube then the red sleeve. then bolt everything down.
check out the tutorial
https://www.civicforums.com/forums/4...-finished.html
Old Mar 12, 2013
samgodbout's Avatar
Nice thread !! I'm not crazy, the rear spring is really too short but I tought it was OK... My front yellow are in the stock insert. I will put it like that on my car and if it's really too low for the rear, I will switch the front with the rear spring. The front are 6 " and the rear 5 "
Old Mar 13, 2013
dont worry about teh rear being too short. i installed 5" rear springs in the friends em2 and it was fine. still had plenty of adjustment and no sag.
i have 6" rear and wish i had 5" instead...
my2k1vic
Nov 29, 2001 10:29 PM
1028CiViC
Nov 27, 2001 02:45 PM
1028CiViC
Nov 24, 2001 02:14 PM
duyaknow
Nov 23, 2001 07:28 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
