7th generation civic suspension
Old Jan 30, 2013
TVR1974's Avatar
TVR1974 is an unknown quantity at this point
A friend of mine has a 99 integra with a lowered suspension. I'm thinking about buying the suspension of him, but I'm not sure if it will fit my 2004 civic sedan. Does anybody know for certain?
Old Jan 31, 2013
GolNat's Avatar
Prelude Owner
Re: 7th generation civic suspension
Do they have the same part number when you look up lowering springs for it?
Old Feb 3, 2013
just take the wheels off both and tell us if they look anywhere similar...
or you could just look in my sig...
Old Feb 3, 2013
BlueEM2's Avatar
Whachya lookin at?
They are different. If you want to have ANY chance of using the integra suspension you will need at least the rear trailing arms, knuckles, shocks/springs, tie rod ends, etc. It will require drilling new mounting hols for the suspension and also possibly fabricating brackets to make it work. It's DEFINITELY NOT A simple bolt on. I highly recommend you buy the right coilovers for your car if you want to lower it.
Old Feb 3, 2013
Tom, he is asking if he can use double wishbone suspension parts in a macPherson type suspension - not gonna happen unless heavy chassis cutting and welding and reinforcing.
he wants to mix 2 older genarations (6th - not even a civic, BTW, to a 7th) and worse yet, posted on the newer generation forums (8th/9th gen).
so, he does not have a clue what he is talking about, nor even to look where he is posting...
Old Feb 3, 2013
BlueEM2's Avatar
Whachya lookin at?
I know Sandro that's why I responded the way I did. The rears aren't tooooo bad... You need :
Knuckles
Trailing arms
Shocks/Springs
The sway bar and links should work. Might need new links though. Rear should be mainly bolt on... never done it though, so I can't be sure.
Fronts are a whole different story. The connecting points are all different and the tie rod placement is different too. You would need
Knuckles
Shocks/springs
Tie rod ends (at least)
Both lower/upper control arms
Then you might run into axle length issues, and all the mounting points would be different... OP I know you wanted a simple answer I'm just elaborating in case anyone else was interested in doing this.
Old Feb 3, 2013
subframes were different too, if i am not mistaken (for the completely different lower control arm) and no mounting points for the upper control arm in the chassis.
and this is still a 2006+ forums
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
GaryFishell
Apr 24, 2015 06:49 PM
Lightman
15
Nov 8, 2001 05:06 PM
SleepyT
Nov 1, 2001 04:59 AM
