spring brand info
Old Jun 11, 2012
jered123's Avatar
jered123 is an unknown quantity at this point
spring brand info
I'm looking at swapping out the springs on my ep3, the old ones make the car much lower than what i want and are way too stiff and since they came on the car when i bought it i figured i'd redo it. I'm looking at the eibach pro series kit, its only supposed to lower it an inch from stock and they are progressive springs. is this brand a good brand and will they work well with kyb gr2 struts? any info helps, this isn't something i want to do twice.
thanks
Old Jun 12, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
Re: spring brand info
Yes that is a good brand of springs. What do you have on the car now? I assume its not stock if they are too stiff..
Old Jun 12, 2012
krudmuphin's Avatar
Eibach is the best of the best in affordable lowering springs. Neuspeed and Tein are also pretty good, but I've heard they tend to sag after a while.
Old Jun 12, 2012
jered123's Avatar
i have no clue one of the previous owners put them on all i know is that its slammed the struts are making noise and i hate the ride height and quality i commute 60 miles to work in a day and it gets annoying fast...what about the struts are those kybs gonna work well with the springs?
Old Jun 12, 2012
jered123's Avatar
so the neuspeed and tein sag not the eibachs right just wanna make sure because the rear of my car is lower than the front by almost an inch and thats not a look i wanna be riding around in
Old Jun 13, 2012
krudmuphin's Avatar
Rears will always be lower than fronts when you have lowering springs. They design them that way for fender clearance on the front. If you want control over the ride height at each individual wheel, you may just want to get coilovers instead. They're more expensive, but give you full adjustability and high-performance handling characteristics.
In your situation, have you also considered just finding replacement OEM springs? That would give you ride comfort and a normal-looking stance again. But if you still want a lowered car, the Eibachs are certainly a great choice.
Old Jun 13, 2012
AutoAnything's Avatar
Former Sponsor
AutoAnything is an unknown quantity at this point
x2^
Eibach's are great and are a popular choice...can't go wrong with them.
Old Jun 13, 2012
not sure for the EP3, but the GR2's might not cut it. they are OE replacement.
tokiko blues? again, not sure of teh EP3's version
