03 Civic si hatchback + skunk2 pro s full c/o
Old Jan 8, 2009
jd03si's Avatar
jd03si is an unknown quantity at this point
just installed skunk2 pro s full coil overs on my 03 civic si. i set them to about 3/4 inch lower than factory heighth. the front coil overs have a helper spring on top of main coil spring that you can basically compress by hand. car rides stiff in back and slightly bouncy in front. has anybody tried removing the helper springs? is this safe? will it affect traction and cornering ? also car would pull which ever way you last turned.
Old Jan 8, 2009
jd03si's Avatar
Re: 03 Civic si hatchback + skunk2 pro s full c/o
I called skunk2 and talked to their tech and told him my problem. even though instructions say to use the helper springs, he said not to on the civic si. i removed them and reset to heighth and the car now handles awesome and goes straight without pull. anyone else had this experience?
Old Jan 17, 2009
jd03si's Avatar
anybody out there with a similar issue?
Old Feb 5, 2009
GremsUSMC's Avatar
GremsUSMC is an unknown quantity at this point
My front suspension is shot. I need new everything (strut, spring, pads) pretty much the assembly and the place I took it to wants to charge 700 plus labor and 465 plus labor for rear springs and shocks do you know where I can get them cheaper?
tylerginevan
Apr 27, 2015 12:29 PM
locozoko
Apr 6, 2002 09:00 PM
ImmortalEX
Oct 20, 2001 09:08 PM
