Need some help
Old Aug 30, 2008
dj_cronic_metal's Avatar
dj_cronic_metal will become famous soon enoughdj_cronic_metal will become famous soon enough
Need some help
Well today I took out my oem shocks and replaced with tokico blues. Since the change i've noticed the steering wheel is off. It's about 20 degree's tilted to the left for the car to go straight, While installing the blues I also installed an ingalls front camber kit. Now when the car is sitting (in park) and I put the steering wheel where it would normally be for the car to go straight the wheels are perfectly straight. Any ideas if an alignment would help here or am I looking at something else or something more serious?
Old Aug 30, 2008
DDragon7's Avatar
Re: Need some help
Whenever you mess with your suspension, you should get an alignment. Sometimes it may look straight but you'll never know until you put it on the machine.
Old Sep 1, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
Re: Need some help
^ Yep.
ALWAYS ALWAYS ALWAYS ALWAYS get an alignment if you work on your suspension, ESPECIALLY if you're swapping the shocks out.
All in the FAQ, man.
Old Sep 1, 2008
Oh1CivicRev's Avatar
Oh1CivicRev is an unknown quantity at this point
Re: Need some help
You definately need to get an alignment done man. I just installed tokico blues and tein springs this weekend and I noticed the same behavior when I took it out for a test drive. Like they say... anytime you do suspension work, get that alignment done!
Old Sep 1, 2008
Re: Need some help
Planned on the alignment, this is the first time i've dropped so I basically just wanted to make sure that I didn't cause a bigger issue. Thanks for the help guys
Old Sep 2, 2008
jgcentury's Avatar
Love me some nice, long-lasting vics!
jgcentury will become famous soon enoughjgcentury will become famous soon enough
Re: Need some help
Any of you guys with the tokico blues have 03-05 civic? If so did you get part#'s HB4020+HB4021 up front and did you have to drill them out to 60mm holes for mounting? Thank you
Old Sep 2, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: Need some help
yes , you caused a bigger issue if you dont get it aligned sooner than later
Old Sep 2, 2008
Re: Need some help
ill be getting ti aligned this week. Oh and yeah jg I had to drill.
Old Sep 2, 2008
jgcentury's Avatar
Re: Need some help
thanks very much dj!
Old Sep 2, 2008
Re: Need some help
no problem hell even with my ingalls kit I still had to drill
Old Sep 9, 2008
DTBear's Avatar
DTBear is an unknown quantity at this point
Re: Need some help
well the camber is part of an alignment. and you swapped it right out? that is 100% an alignment problem
Old Sep 11, 2008
Re: Need some help
always align after doing ANY suspension/wheel mods. even sway bar! and do it asap
Old Sep 11, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: Need some help
i have an 04 with Blues, and yes i had to drill them out a bit. patience and a step bit are your friends.
Old Sep 12, 2008
Re: Need some help
car is fixed. Alignment does wonders. Then the two tires I added to the other two new tires. Followed up by a cracked rim wheels/tires/suspension is expensive.
