Eibach Pro Kit, Lowering Coil Springs
Old Apr 9, 2008
carter's Avatar
carter is an unknown quantity at this point
EIBACH PRO KIT, LOWERING COIL SPRINGS, and 1" drop front and rear. How would these springs do for just a minor drop.
If im looking for a small drop as such do I need a camber kit ? What about new dampners? I want a close to stock ride. I was told some lowering Springs with a minor drop and your stock shocks and struts will give you the softest ride??
Old Apr 9, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
Re: Eibach Pro Kit, Lowering Coil Springs
yes you need a camber kit. there are a lot of different threads covering this topic in detail; i would definitely search for those and read through them. as for a small drop, the one inch should do it. the stock shocks will hold up for a while, but how long depends on several different factors (current condition, future driving conditions, etc).
Old Apr 9, 2008
CivicFreak03's Avatar
CivicFreak03 has a spectacular aura aboutCivicFreak03 has a spectacular aura about
I have the eibach pro kit with a SPC camber kit. No matter the size of the drop you need a camber kit. I got a printout from the shop that installed mine and they did a reading before and after the camber kit. Huge difference! I had mostly negative camber readings before the camber kit was installed. With the Eibach prokit you have about a finger and a half gap between the tire and fender.
Old Apr 9, 2008
familycar's Avatar
I have the prokits with KYB AGX shocks riding on 225/40/18 nad my camber is with in spec. I dont use a camber kit and get 25-30k out of my tires. Towards the end of their life the tire will show some minor camber wear, but besides that it has been a great set up.
You SHOULD run a camber kit, but with only 1" drop its not necessary and hasnt effected my tires wear enough to warrant doing it.
Old Apr 9, 2008
carter's Avatar
www.autopartswarehouse.com
what setup could I get from there for my Civic 2004
Ebachi Pro Kit and some Shocks should do the trick? But if i change the shocks it will be a more stiffer ride no?
FamilyCar What bout Koni Shocks I have option between thoes and KYB.. How is your ride quality. Im loooking for a drop not a racing car
Old Apr 9, 2008
familycar's Avatar
AS you can tell from my SN this is/was my family car. The ride is as close to stock comfort level as I have experienced. The progressive coils give good compression in the corners but stays fairly soft for normal driving. The KYB AGX shock sI have allow me to dial in the suspension feel. They are 4 way adjustable. I usually ride on #2 when the family is going to be in the car. I recently bought my wife an 08 grand cherokee though so tht is now the family car so I have stiffened up the shocks for my taste and driving style.
Old Apr 9, 2008
carter's Avatar
So with this pro-kit being its a family car what would you reccomend I have not much knowledge of the adjustable settings unless they come pre-programed and dont require a lift or major tools to make these adjustments?
Old Apr 9, 2008
familycar's Avatar
The adjustment is done with a little screw driver(provided) under the hood and in the trunk on top of the shock. They are clearly marked with numbers. The higher the number the stiffer the shock will be. Even my 5yr old could do it. No lift, no jacking up the car. Just turn the adj. screw.
Dezod shold have them for you and will probably match any price. Otherwise I bought mine locally from Dynamic Autosports in Lake Forest, Ca. (949) 334-0541
or
http://www.dezod.com/pd_eibach_prokit_springscivic.cfm
and
http://cgi.ebay.com/ebaymotors/KYB-A...spagenameZWDVW
Old Apr 9, 2008
prokit only drops 1 inch with the right shock (ie, tokicos or some other aftermarket rated for lowered car). otherwise it will be very weird with stock shocks. sagging, wrong height, all sorts of issues. and yes camber kit is needed. my settings were all in the red before they put the kit on and realigned.
Old Apr 14, 2008
familycar's Avatar
i still am not in the red after 2 years of riding with out one
true what they say every car is different
Old Apr 14, 2008
inthezoneac's Avatar
inthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trusted
I heard anything more than 1.75" and you'll need a camber kit, but anything less and you don't.
But as always, get an alignment done no matter how much you drop you car.
Old Apr 14, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
haha drop your car 1.75" without a camber kit and your wheels will look like this:
Old Apr 15, 2008
ok, maybe I should say drop you car more than 1.5" and you WILL NEED a camber kit, anything less and it's not too bad. And a little negative camber will give you better handling. Get an alignment so the toe in/out, whichever one occurs after a drop, doesn't eat your tires in a few weeks.
Old Apr 16, 2008
Kirie's Avatar
Kirie is an unknown quantity at this point
I'm a newbie here, just bought eibach pro kit today..i have some questions;
1. what is a camber kit?
2. why I got 1.5" drop at rear and only 0.5" drop at the front after installing pro kit?..very confusing, the ads say it will only be 1" drop..
Old Apr 16, 2008
SilverCivic504's Avatar
SilverCivic504 is an unknown quantity at this point
I had prokit on my 05 for a yr now. I recently had to get camber kit because the left rear was wearing down pretty bad. Dont have a problem with the factory shocks. The drop use to be a lower in the back prior to the cambers being installed but it even'd out after.
Weird thing was i didnt have a problem with tire wear on the factory 15s. But when i put the 18s on they wear pretty fast. Guess it has to do with the tire width
Old Apr 16, 2008
Kirie's Avatar
Question Re: Eibach Pro Kit, Lowering Coil Springs
btw, what is camber kit I'm just a newbie..do help me
Old Apr 16, 2008
Kevbotron's Avatar
I like my commute
Camber arms that come stock on your Civic have an alligment to what the stock specs are for stock shocks/springs.. an aftermarket camber kit is adjustable, and allows your car to have proper allignment when the stock camber arm will only stay to one specification, and thus, you not being able to have a perfect allignment when you lower your car the front are merely different camber bolts instead of arms.
Old Apr 16, 2008
Kirie's Avatar
oic..just realized it now..so i've to spent some fortune for the camber kit now..
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
izdman
May 19, 2015 03:43 PM
Exbauer
Nov 22, 2001 08:23 PM
CivicVTec
Nov 11, 2001 05:36 PM
