need help, which springs?
Old Jan 25, 2008
phenom's Avatar
phenom is an unknown quantity at this point
hi
i need your help.i've got a civic hybrid 4dr and i want to lower my car.
for my civic i only can get springs from
eibach, vogtland and b&g
so i can't decide....what is the best combination with stock shocks?
i heard that the eibachs make some clocking,knocking sounds in the rear.
if you have pics of lowering with eibach prokit,b&g and vogtland i would be fine
excuse my english!
Old Jan 25, 2008
sl33pyriceboi's Avatar
Re: need help, which springs?
why can u only use those springs? hybird uses diff springs/struts then regular civics?
id go with eibach for springs...they're alot more reputable than the other two
Old Jan 26, 2008
robbclark1's Avatar
Retired suspension supermod.
Originally Posted by phenom
hi
excuse my english!
I highly suggest NOT lowering your car that much and NOT lowering it on stock shocks. All of us have non-hybrids. We do not know the effects of lowering a hybrid because of all the extra equipment and weight distribution. If you want to lower I only suggest no more than 1" with Tokico HP (Blues).
Old Jan 26, 2008
eat111's Avatar
eat111 is an unknown quantity at this point
I have a similar question. I also have a hybrid. I want to get new springs/shocks, but do not want to lower the car. What are your recommendations?
Old Jan 27, 2008
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
get oem parts since you don't want to lower your ride...no aftermarket spring/shock combo won't lower your car.
Old Jan 27, 2008
eat111's Avatar
Thanks Rjngo, that saves me a lot of research.
Old Jan 27, 2008
robbclark1's Avatar
Just replace your shocks with OEM or Tokico. Springs should be fine.
Old Jan 28, 2008
phenom's Avatar
i talked to technicans from eibach, kw and vogtland here in germany.the hybrid has an axle load from 800kg in the front and rear and a weigt from 1260Kg.its the same like the ES with the 1.7 engine.
the springs for ES are also for EM/EP/EU
so it can also be use for a hybrid.
try the link here http://php.vogtland.com/get_pdf.php?...2TG0902-00.pdf
thats an german TUV certification.they will add the ES9 (hybrid) soon.
sorry for my english
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
