Coilover spring binding and sound fix!
Old Nov 16, 2007
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Finally found something that will work to relieve the spring pressure in all of us that have coilovers that pop, tong, or just have pressure (if you don't hear it, you probably still have it, which prevents smooth steering). I've tried plastic washers and metals ones that came with my Ksports and even custom nylon washers, but recently found a bearing available specifically made for coilovers with an inside diameter of 2.5"
http://store.summitracing.com/partde...t=hal-7888-109
It's called a roller thrust bearing, which is essentially a washer with a number of rollers in it that sit across the washer face. On either side goes a metal washer that spins on the rollers. For $35 shipped, it's a pretty cheap fix.
I'll update next week when they're in my car, but for now, I'm 95% sure that these will work. I took some pictures below for sizing reference and a better description.
Inside Diameter (2.5")
Outside Diameter (3.25")
Old Nov 16, 2007
robbclark1's Avatar
Retired suspension supermod.
Re: Coilover spring binding and sound fix!
good find noobie...
Old Nov 16, 2007
speedfoos's Avatar
Good stuff man. +1 for you when I can rep again.
Old Nov 16, 2007
kl103's Avatar
kl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trustedkl103 should not be trusted
sweet. i need this!
Old Nov 17, 2007
Da1lyDr1ver's Avatar
lets not jump the gun and say that these work. you havent even intalled them yet.
good luck with them tho...
Old Nov 17, 2007
bakertime's Avatar
Definitely, but I've got high hopes. I will definitely update, and thanks for the good luck.
Old Dec 3, 2007
kl103's Avatar
anyone tried this yet??
Old Dec 3, 2007
bakertime's Avatar
Yeah, sorry haven't had the chance to update. This has pretty much eliminated the problem entirely. I had a day where the sound came back, but it went away the next. I didn't use lubrication, so that may be a nice insurance policy too.
I'd highly reccomend them! They're way better then any other option I've tried.
Old Dec 3, 2007
kl103's Avatar
what do you mean by insurance poilcy??
Old Dec 3, 2007
bakertime's Avatar
Just gives it one more way to roll smoothly. They're pretty smooth as is, but it just adds to that.
Old Dec 4, 2007
wontonamo's Avatar
wontonamo is an unknown quantity at this point
nice find
Old Dec 4, 2007
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
hey bakertime, u should put some pictures of you putting the bearings on. like a diy. that be nice. thanks
Old Dec 4, 2007
bakertime's Avatar
Sorry man, I didn't take any pictures. It's really pretty easy. First take loosen the top bolt on the strut, then remove the entire strut from the car. Make sure the spring isn't under pressure (if it is, use a spring compressor or move the bottom spring perch down) and finish removing the top nut. Take the pillowball mount (or whatever you have on top) off and lift off the spring. Sandwich the bearing between two metal washers (included) and place them under the spring. Then just do everything in reverse, and repeat for the other side.
That is assuming you know how to remove and install the suspension. If you're not familiar, check out the DIY spring install.
Old Dec 4, 2007
robbclark1's Avatar
We trusted you for a DIY...that's it, you're b4nn3d!!
Old Dec 4, 2007
bakertime's Avatar
haha
Old Dec 5, 2007
mrbanhbao's Avatar
i have some crap skunk2 coilovers (not fullcoilover), so would this work with my setup?
Old Dec 5, 2007
bakertime's Avatar
Well they're for a 2.5" ID (Inner Diameter) spring, so if they're that, and it has a flat surface under the spring for them to sit on, then yes. If they're stock sized springs, or have a detent for the end of the spring, then no.
Old Dec 6, 2007
mrbanhbao's Avatar
hm i know they're not stock size, but here's a pic of exactly wat i got. kus i lost my bearings and it makes noises when i turn slowly and etc..
http://got-jdm.com/images/coilover_skunk2_new.jpg
Old Dec 6, 2007
robbclark1's Avatar
2.5" around (measure if you want) and get some of the bearings that bakertime is talking about and install at the top of the spring or top spring seat.
Old Dec 6, 2007
TIPPMANN's Avatar
TIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond repute
Good find!
I will be purchasing some in the future...
Old Dec 7, 2007
exturbo6's Avatar
dam nice find, so this replaces those bearings in the top of the strut then?
Old Dec 7, 2007
bakertime's Avatar
I used it on the bottom of the spring, between the bottom spring perch and the spring. At least on Ksports, my top perch spins pretty freely on the shock body. Really you could use them wherever you choose though.
Just a heads up, I've noticed that because my bottom spring perch is staggered on the edges, the bottom washer has bent slightly. If you have extra metal washers, it'd probably be a good idea to double them up if this is your situation.
Old Dec 7, 2007
exturbo6's Avatar
so this could be a good part to use to replace the bearings on the top of the tower then?
Old Dec 7, 2007
mrbanhbao's Avatar
yeah i guess i can do that. but my struts are prolly blown. i was planning on getting full coilovers. do i still need it (leaning towards TEIN)? i was told that i dont need any bearings (stock one) if im getting full coilovers. IS THIS TRUE?
Old Dec 7, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
ya my OEM suspention came with a ball bearing one with grease in it...
Old Dec 8, 2007
bakertime's Avatar
I think you guys may be confusing this with the OEM bearing. This IS NOT the same. It can only be used on 2.5" coilovers (I've only used on full coils, not sleeves) and it's designed to be used on the BOTTOM of the spring. It allows for the spring to turn. It does serve the same purpose of the OEM bearing, but is in no was a replacement part or an alternative. The OEM bearing sits between the spring top mount and the top mount on the strut. This bearing actually contacts the spring directly. (But again, they are for two different applications). Hope this clears some confusion up.
For the Teins, I've heard most people don't have the problem I did, so I'd say try it w/o and if you have a problem, then get 'em.
Old Dec 8, 2007
mrbanhbao's Avatar
cool thank you
Old Dec 8, 2007
robbclark1's Avatar
Binding usually occurs at the top and it can be used with things like GC coilovers at the top because you use a special plate that attaches to the bearing.
Old Dec 10, 2007
exturbo6's Avatar
will this work on neuspeed springs and bliestein struts. or just coilovers like stated?
Old Dec 10, 2007
robbclark1's Avatar
just coilovers with a 2.5" spring.
