Spacer for rear springs?
Old Aug 29, 2007
twistitup's Avatar
twistitup is an unknown quantity at this point
2003 civic dx, tokico blues/stock springs.
I want to reinstall my Tein S.Tech springs because my car's way too high and rides pretty bumpy/stiff. The higher spring rate of the S.Techs will probably smooth out the over damped ride.
However, when I had my springs on the stock shocks, the rear was a bit lower than I wanted. Is there anyone who makes a metal, rubber, or plastic spacer to add a bit of height to the car in the rear? The spring would sit on it, or you could put it on top of the shock top mount.
Has anyone else tried or done this?
Thanks
Old Aug 29, 2007
Kevbotron's Avatar
I like my commute
Re: Spacer for rear springs?
well I don't know anything about spacers, but I think you'll find that the ride height evens itself out w/ the blues as opposed to the stock shocks. My rear was saggy w/ my stock shocks, and when I put the blues in, the height is even front and rear that was w/ the ProKit though, not Tein.. but isn't the drop similar? the prokit does 1.3" ..
Old Aug 29, 2007
twistitup's Avatar
I think that the blues will make a difference in the height too, but I'm not 100%, it's possible that my rear was lower from weak/blown shocks.
I still wouldn't mind a slight rake towards the front, but even would be better than *** sag.
thanks for the info,
Anyone else?
Sep 26, 2023 06:44 PM
GotSiR
Jun 23, 2016 04:06 PM
GritzNGravy
Aug 19, 2015 03:03 AM
Mr.Beefy
Aug 12, 2015 04:39 PM
Curtchuk
Aug 5, 2015 02:14 PM
