Should i go with s-techs and tokicos or oem springs with tokicos???
so i've had the s-techs on for about 3 years on stock shocks and they've been blown out for a while and i finally got my tokico blues.....i'm torn on deciding if i should keep the s-tech's on and install the blues or just going back to oem springs and installing the tokico,,,because i reaaaally don't want to have to deal with changing the suspension again if the s-techs are gonna blow out the tokicos in a few years too.......... can anyone input their experiences on this?? and please don't say "they shouldn't blow out with s-techs, blah blah", i'd like responses from experience, thanks
Re: Should i go with s-techs and tokicos or oem springs with tokicos???
what is the drop for those spring? tokico is fine upto 2 inch. you can call and ask them too to make sure. its made for lowering springs. with stock springs, the ride is gonna look really high, i doubt youd be happy with it. and its gonna be alot firmer.
"so i've had the s-techs on for about 3 years on stock shocks"
thats why theyr blown. keeping oem springs with new shocks (when u have teins) makes no sense to me ...might as well put them on
is there anyone that has the tein and tokico combo with a coupe? i can't find it since this stupid site changed from 7thgen to civicforums...
my left rear is more like 3" drop now since it's sagging, i'm wondering if that damaged/compressed the teins so that it'll be lower than 1.5" if I put on the tokicos, thus blowing out the tokicos in a matter of a couple years since the the spring was compressed beyond the 1.5" drop rating with the 2.0" drop rating with the tokicos??? jus throwing it out there...
same thing happened to me. rode with prokit and stock shocks for 2 yrs, the rear was slammed, the front was 3 finger gap, then i had them put new tokicos, everything changed to 2 finger gap. i really dont think spring compression can be changed or messed up, it stays the same. its the shocks that can change the ride height depending if theyre good or bad.
I will post pics tonight after I get off of work of my coupe with s-techs and tokicos. I actually had tokicos and neuspeed race springs and quite a few people were saying they had problems with the race springs being too low for the tokicos, so I went ahead and got the s-techs. Ride feels great. I have only had them on for about a month and a half, so I don't know how they will be in a year or 2 or 3. Tokicos have a lifetime warranty though. So I would go ahead and put them on, just with that peace of mind.
The World Is Yours!
well get some Tokico's, theyre great i hear, but i love my KYB AGX, and get a Eibach or Tanabe spring
I was on tein s-techs with tokico blues and the ride felt great.. i then sold them to my friend because he had blown shocks in his 01 sedan and I got ahold of a set of tein ss-p's
I would suggest buying new springs before you install.
I used new tokicos with used springs and the shocks blew within 5 months. I drive on bumpy roads so that is a factor in them blowing, but still the springs are used.
Since then, I bought new blues and new s-tech springs. The set up with all new parts is much better.
I haven't had a chance to take many pictures since the new setup, but here is the best one I have and I tried to lighten the picture so that you can see the wheel gap in front and back...
Hope this helps and good luck!
sorry no but i have to disagree. springs are made to outlast the car and then some. they dont go bad for any reason. i bought my springs used and rode on 3 yr old stock shocks for another 2 yrs before they finally gave up and the fronts started leaking. how fast you blow shocks depends on how you drive and the potholes you run into. but dont blame it on the spring, unless the ones you have gave too low of a drop that the shock couldnt handle/wasnt made for.
Does the rear sag like it does with the stock shocks??? thanks a lot!
I will be taking pics of my car with the new setup (s techs and blues) later today. finally got some decent weather. i don't think you'll be happy with the ride quality, or the appearance of stock springs on blues. I know you asked for no speculation, but i think you should be fine using the s techs you have. If you're truly concerned that they'll damage the blues, pic up a new set of s techs. mine were about $130 shipped on ebay, if that, and they're legit, not that counterfeit **** going around. Unless somehow the springs were permanently compressed, you will be fine with s techs on blues. the s techs are rated at 1.4" front, and 1.3" rear, or the other way around, i forget. They're definitely less than the 2" drop the blues are designed to handle.
I do drive in a rather bumpy area, but I don't drive aggressive or fast.
What causes the car's suspension to do this:
The drivers side of the car is lower than the passenger side by 1" or more.
I have been told it is because the engine and driver are on the left, being a weight issue. If someone uses their new springs for two years, and sells it to someone else, you say they will not have this problem, or wear any more than new springs? (Using the same set up)
This has always made me wonder so let me know what you think gear. From experience, I never trust anything used anymore.
springs dont really stay compressed tho after being taken off the car. they return to the original configuration. i agree the driver side is a bit lower, but nowhere near a whole inch, even with the driver. go take a pic of your car with and without you in it, i doubt you could visually see a difference. and its not really a problem, just something that happens. idk, springs really cant wear out, it just seems impossible. if they did, then wouldnt spring replacement be part of maintenance? like replacing spring with the shock or something. i asked the alignment shop this a long time ago and they looked at me like i was crazy. they said they only replaced the springs on a few cars and that was changing with aftermarket. nobody has ever replaced stock spring. and like i said, just off my experience, my car was really saggy in the rear almost slammed with no gap when i had full gas. and it was this way for two yrs, then i had just the shocks changed and the gap rose above 2 fingers which is a huge noticable difference. which means that the spring immediately returned to its original configuration (1 inch drop) with good shocks. if they were damaged spring, they shouldve stayed slammed right? alot of people make that mistake and blame the spring, when i put prokit on at first i was shocked how low they went, and everyone was blaming the spring saying yeah it always sags on sedans. well turns out that wasnt true at all, the spring is perfectly fine, and thats after 2 yrs of use and more by whoever had it before me. right now they are at the perfect height they should be. and i doubt it will ever change until my shocks blow again. springs are one of the few things that dont matter if its used.
could there be a possibility of fatigue on the springs?
I still think maybe the driver side is lower than the pass. side due to the fact that right turns are generally attacked at a tighter radius and higher speed, whereas left turns are usually slower and bigger radius because of yield-to-traffic situations and longer red arrow lights. There is a 0.25 inch difference between left and right on my car
hm okay, i think i'm leaning towards going with the s-tech/tokico combo. I'm just wondering if the rear still sags with the tokicos and if having a full tank of gas affects how much it sagged.(which my stock shocks did).
My rear sags maybe half a finger compared to the front. I have a box with 2 - 12 inch subs in the trunk, so there is additional weight in the rear as well. The difference is not real noticeable to the average person. I say you would be much happier with the tokico and s tech combo IMO.
