Help need suggestions
Old Jun 20, 2007
flipcrip's Avatar
flipcrip is an unknown quantity at this point
Unhappy Help need suggestions
sup guys, i noticed the other day as i was trying to loosen one of the bolts for the front strut tower that it would just keep turning. Meaning it would not tighten or loosen. just wondering if you guys have any suggestions for removing this bolt(14mm) thanks in advance guys
Old Jun 20, 2007
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Re: Help need suggestions
is there a nut or bolt on the other side??
Old Jun 20, 2007
speedfoos's Avatar
Are you talking about the one in the center of your strut? The one in the center of the other three bolts? Typically you need an impact wrench to get that bad boy off. Since the shaft will just spin and spin with a normal wrench or ratchet, an impact will 'pop' it off and allow it to loosen. They can be a real bitch. We had to cut two of them off a Saturn yesterday.
Old Jun 20, 2007
Alpha 5's Avatar
If he is talking about the one in the center of the three, that would be the actual strut rod. TO loosen that bolt use a wrench with an allen in the center of the shaft. The allen will keep it from spinning.
Old Jun 20, 2007
speedfoos's Avatar
Humph. My teins don't have the Allen hole. I got ripped off.
Old Jun 20, 2007
flipcrip's Avatar
its one of the three bolts around the center one. i have an aftermarket strut bar that i want to remove, and one of the nuts supporting the strut just wont losen or tighten. thanks guys
Old Jun 20, 2007
speedfoos's Avatar
Blech. Stock suspension? I take it the whole thing is turning - bolt and nut - yes?
Old Jun 20, 2007
flipcrip's Avatar
not sure about the bolt but definitly the nut
Old Jun 20, 2007
flipcrip's Avatar
and yes its the stock suspension
Old Jun 20, 2007
flipcrip's Avatar
i was thinking of just cutting the bolt and then just purchasing the top strut tower, what do you think?
Old Jun 20, 2007
speedfoos's Avatar
Might be. That mount is only $36 from Majestic Honda. I'm fairly certain those studs are welded on so you probably can't just replace the bolt. Put a normal box wrench on it first to see if it's just the nut spinning or the whole thing. If its just the nut, you can get a splitter, take it off, and then rethread it. Would save you the work of dropping the entire strut to replace the mounting plate.
Old Jun 21, 2007
jamis33's Avatar
You Stay Classy, San Diego
ya just cut it off. Its prolly cuz its all rusted out.
Old Jun 21, 2007
flipcrip's Avatar
thanks guys....one question though.....what should i use to cut the nut off, is there a special tool or just use a hacksaw?...thanks
Old Jun 21, 2007
Alpha 5's Avatar
Use a nut splitter....
Old Jun 21, 2007
flipcrip's Avatar
thanks for all the info and help guys.....ill post an update
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
J-Fly
Sep 10, 2015 08:39 PM
