Please help me figure this problem out!
Old May 31, 2007
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I am really confused as to what could be wrong with my car . I went to get it re-aligned today and after 3-autoxs and 2 months the front left was WAY out of wack. We started at -2.2 and today it was -1.6, we ended up putting it back in place (I decided to go with -2.0 on the front due to traction issues).
As I was leaving the shop upon my initial forward movment in 1st I noticed a very distinct sharp click from the front left tire well. Upon lifting the throttle I noticed the same sound. I continued hearing this sound upon initial throttle (even slight) and everytime I lifted throttle no matter what gear I was in. However, it would NEVER happen while braking. I took it back to the shop and had them look at it. Out in the parking area the tech eased off of the clutch in 1st as I watched and almost every time we got the same sound, from my perspective it also looked as if the tire hesitated to roll forward. We put it up on the rack and checked all of the bolts and everything was tight. We then checked for play in the tire thinking it could be a wheel bearing, and no side to side play. We even went as far as putting it in gear on the rack and having me drive it and duplicate the off/on throttle and again nothing. Our final test was sudden movements back and forth while in neutral with the car on the ground and still nothing.
I am really confused as to what this may be, I am not sure if it is even related to the sudden change in alignment, but I do find it odd. My initial thought is wheel bearing, but I think I would have play in the tire on or off of the rack. My next thought is tie rod end, or ball joint at an extream angle under the new camber, but this should make sounds even while braking. My only real thoughts are that the CV joint is at a strange angle and is poping in and out of place (but again it seems as if this is not dependant on on or off brakes) or the hub nut is lose and it is pulling slightly in and out. I also thought maybe the differential in the tranny could be bad (there is about 1/8" of axle rotation before the gears feel like they grab. I really don't have a good answer, the tire is off and nothing really sticks out.
Symptoms:
-significant change in front camber on this side
-ONE sharp click from the left side with sudden accel and deccel, no other time
-does not happen unless weight is on the tire
-does not happen when on the brakes
-does not happen unless the car is in gear
Old May 31, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Please help me figure this problem out!
Check the LCA bushings and the ball joint. If its only on the gas, it could be the axle nut, something in the splines or something as dumb as the brake pad shifting in the caliper.
Old May 31, 2007
EMK20a2's Avatar
Thanks man!!
when you say LCA bushings you are talking lower control arm, correct?
Old May 31, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
mines did the same thing.. the LCA bushings went.. pressed in some energy suspension ones
ywgflyer
May 15, 2015 05:05 PM
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
RickyRocket
Nov 30, 2001 10:14 AM
