Installing springs/ knocking sound
Old Dec 13, 2006
TOPEM_II's Avatar
TOPEM_II is an unknown quantity at this point
Problem fixed, thanks to everyone.
Old Dec 13, 2006
TOPEM_II's Avatar
The noise is comming fromt he driver side for sure, We gonna try to but those little metal ***** back in today and see whats gonna happen. Ill keep you updated guys, but if anyone can give me some advice please e-mail me
Thanks
Old Dec 13, 2006
TOPEM_II's Avatar
whats the allan wranch size that you use on the back shock/ the top bolt a 5mm or 6mm. B/c my buddy stipped the screw on top So I wanna make a sure to use the right size on the other shock.
Old Dec 13, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Okay, first things first. Did you install the bearing on the drivers side or not? If not, found your problem. If you did, are you sure all of the bearings were put back in? The strut bears on the bearings and should make noises if it is not there or if all the bearings were not put back in.
And the rear allen key is 5mm. THIS DIY is your friend!
And please make sure you index the struts correctly!
Old Dec 13, 2006
TOPEM_II's Avatar
No the bearing was not put back on the driver side, I guess we found the problem
Old Dec 13, 2006
bobsagator's Avatar
And THIS is your basic installation sequence and orientation.
DVexile
Jul 2, 2021 05:25 PM
danace99
23
Jun 28, 2015 08:49 AM
Supramk3
May 11, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
