New Member Needing Help
Old Dec 8, 2006
SILVER02's Avatar
SILVER02 is an unknown quantity at this point
Wuz Up Members, I Plan On Installing Ss Teins W/ Pillow Ball Upper Mounts On A 2002 Sedan. Will I Need To Install Camber Bolts Also?
Old Dec 8, 2006
CivicUpgrader's Avatar
CivicUpgrader is an unknown quantity at this point
not tooo sure but ill bump you^^^
Old Dec 8, 2006
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
ill bumo u
Old Dec 8, 2006
tnel2005's Avatar
tnel2005 is an unknown quantity at this point
depends if you want your tires to wear out or not.......if you do then leave them off......if you dont put them on .
Old Dec 8, 2006
SILVER02's Avatar
Its My Understanding U Can Adjust Camber W/ The Upper Mounts
Old Dec 8, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
That understanding is correct. Camber plates don't need bolts, but make sure your alignment shop knows how to use them
Old Dec 10, 2006
SILVER02's Avatar
Thanks Alot For The Info.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Myredjonda
Apr 14, 2015 07:00 PM
