02-06 Rsx J's Racing Adjustable Ball Joints
Old Nov 23, 2006
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Are these roll center adjuster a fit for the 05 Civic Ex? These are exactly the same as ball joints correct? Im thinking of getting these with the DC5 beefed up tie rods.
Heres a link to the adjusters.
http://www.jsracing-net.com/catalog/...1&cat=6&page=1
Thanks
Old Nov 23, 2006
Synapz's Avatar
Synapz is an unknown quantity at this point
U need the EP3 ones, i heard the studs on the DC5 ones are bigger as well
but I think this is the last suspension upgrade u should do, because of the cost, and how extreme it would be because you would only "need" these if you're really spirited at going to the track with your car
Old Nov 23, 2006
Boggie1688's Avatar
Diamond Member
The only reason why I'm even looking into this is because I'll already be in there working on the bushings and the tie rod arms. And with a bushing swap I need to remove the control arms and this would be a perfect time to install those RCAs so I won't have to deal with alignment and install all over.
Old Nov 23, 2006
Boggie1688's Avatar
Diamond Member
Uhh got a response from A&J the ball joints won't fit the Civic...but they said the tie rods wouldn't and I check the part numbers of honda they use the same tie rods and tie rod end so I'm sure those fit. Do you know anyone else that makes RCAs for our cars?
Old Nov 23, 2006
pinoyjdmr's Avatar
pinoyjdmr is an unknown quantity at this point
dude the ajustable ball joints are the **** I got the steering rods to for my car and dude it handles like a champ and it's lighter than out stock ones and it much nicer to, it wort on getting it and like what I said it handles like a champ the steering it gotton lighter get it and you'll see the diffrence on the performance oh dont over tighten the ball joint may cause to snap and if its the corect specs mark it and use lock tight and it will be all good ......
Old Nov 23, 2006
Boggie1688's Avatar
Diamond Member
Sweet man but which ball joints did you get? I can't find any that fit our cars!
Old Nov 23, 2006
Synapz's Avatar
i can say that the J's racing reinforced tie-rods definately fit EM2s... and im pretty sure the roll-center adjustable balljoints do too.
Old Nov 24, 2006
Boggie1688's Avatar
Diamond Member
Well hopefully pinoy can confirm that RCAs.
A&J has no return policy once you buy u can't return it.
Thanks for Everyones Help!
Old Nov 24, 2006
pinoyjdmr's Avatar
oh hell yeah the RCA from J's works as well also slips right in with no drilling or whats so evers on that and I for my self like it more than my stock ones oh and the shop I went to purches the parts said it couldn't fit but i gave it a try and it did fit and proved them all wrong I guess they need to do more reserch than saying it's not going to fit @ all but dude get the full J'racing RCA and the tie rods you'll be more please than ever...........
Old Nov 24, 2006
Boggie1688's Avatar
Diamond Member
Aites Ep3 Tie Rods and RCAs it is!!
Wish me luck guys!
Old Nov 24, 2006
Synapz's Avatar
It will fit! AJR are local guys here, and I know for sure that they dont study EM2s, because its such a "family" car.
jackoncruzpr
Sep 29, 2015 07:59 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Joecrowe
Sep 24, 2015 09:12 AM
