Steering wheel shakes at speed
Old Nov 1, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
When i get up to aroued 60 mph, my steering wheel begins to shake. not horribly, and not enough to affect the direction of the car. The problem started right around the time i installed my lowering springs. the car was aligned right after the spring went on, but it has been a problem since hten. does anyone have any idea what could be causing the shaking?
Old Nov 1, 2006
robbclark1's Avatar
Retired suspension supermod.
unbalanced tires
Old Nov 1, 2006
CaTacL1sm's Avatar
CaTacL1sm will become famous soon enoughCaTacL1sm will become famous soon enough
think so? when i got my rims, i had them balanced and a while later i noticed the slight vibrating in the wheel.
Old Nov 1, 2006
susuking's Avatar
susuking is on a distinguished road
then they did a bad job at balancing.
Old Nov 1, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Badly worn tires can also cause vibration, especially if you rotated them recently. No amount of balancing will fix it.
Old Nov 1, 2006
lxcivic2k1's Avatar
If you have rims they usualy don't do the clip on weights like they do on steelies, they glue them to the inside and they have tendency of falling off. I had mine balanced last august before school started and its shaking again now.
Old Nov 1, 2006
ZCivic's Avatar
ZCivic is an unknown quantity at this point
could be a bad tire or a bad alignment job
Old Nov 1, 2006
sl33pyriceboi's Avatar
if u got ur wheels ballanced and ur alig. done......then its none of those....
and since u did say u just got rims.... you might want to look into hubcentric caps
Old Nov 1, 2006
AmbulanceMonkee's Avatar
I by no means claim to be an expert in suspension, as mine is stock. But everything i've read on lowering/suspension modification seems to say drive it for a while, let it settle, then get it aligned. Maybe you need another alignment?? Maybe your's was done before it settled?? I dunno, anyone else heard this??
Old Nov 2, 2006
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
Get some hubcentric rings def as it really helps the rims settle against the hub. Get your tires rebalanced too.
Old Nov 2, 2006
Ashhole's Avatar
thx for the advice guys, i have had the rims for a while. I never thoughtof what amnulance mentioned, having it aligned before the springs settled. thats VERY possible.
Also, would my camber being off by about .7 degrees affect it at all?
Old Nov 2, 2006
CaTacL1sm's Avatar
have the hubcentrics, ill go get them balanced again then.
Old Nov 2, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Bigger rims will have more rotating mass on the lips having way more inertia....
I have 17 wheels and mine shakes too..just make sure the weights are still in rims and clean the inside for any debris
Old Nov 4, 2006
thecheat's Avatar
thecheat is an unknown quantity at this point
tires. as they wear the balance changes. rebalance
Old Nov 4, 2006
kasimmmmm's Avatar
it could be the balancing, one of the wheels is bent, need alignment. check all those... are your tires on the right pressure?
Old Nov 4, 2006
kuNhoHan's Avatar
kuNhoHan will become famous soon enough
strut will help but i have hub rings , balanced wheels, all that but the fact that im running 17's on 205-40-17 i would get vibration after going past 60-70 so i would recomend a camber kit and strut
Old Nov 4, 2006
Ashhole's Avatar
already have the sturt bar, but i do need a camber kit
Old Nov 4, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Alignment wont cause a vibration... It will cause your car to pull, wear tires quickly/uneven and maybe handle poorly but it WILL NOT cause a vibration.
These can:
Wheel/Tire Balance
Defective Tire
Bent Rim
Blown Struts
Broken Engine mount
Worn/Unbalanced Axles
Old Nov 4, 2006
Ashhole's Avatar
ooo blown strut. would not have thought of that one. im about 90% sure my drivers side from strut is blown.
also i have uneven tire wear from a lack of front camber bolts to make adjustments
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
anddrrey
May 11, 2015 02:30 PM
RickyRocket
Nov 30, 2001 10:14 AM
