Help With Poly Front Control Arm Bushings
Old Oct 11, 2006
HectorM52's Avatar
HectorM52 is an unknown quantity at this point
I searched around and everyone said that they needed to have their front control arm bushings PRESSED IN. OKAY, I'm cool with that.
BUT, my bushings look like their is a lip on both the top and bottom that I would have to assume helps to hold the bushing in place. What I'm worried about is basically tearing/slicing one of those lips off when it is pressed through the hole.
Has anyone had this problem?
Has anyone actually seen it done so you can say the lip is okay??
Any insight?
Old Oct 11, 2006
Zzyzx's Avatar
Autocross Junky
The lips bend in...
Did my own install, 0 problems with tearing or what not.
Old Oct 11, 2006
HectorM52's Avatar
Thanks - your name was in one of the threads I found. I was going to PM you but thought this would be faster...
I'll let you guys know when I'm complete!!
PS - do you think Pep-Boys could handle this or do you think that I should try a Honda stealership???
Old Oct 11, 2006
Zzyzx's Avatar
Autocross Junky
Its not a hard insalation... Just kinda time consuming. so either should be fine, but I'd suggest getting a quote from both.
Old Oct 11, 2006
robbclark1's Avatar
Retired suspension supermod.
I wanted to ask about the ball joint? Do you just pop the arm out and then back in? Sorry to jack the thread.
Old Oct 11, 2006
Zzyzx's Avatar
Autocross Junky
Me and a 3lb "mini" sledg hammer poped that thing out easy... hit the LCA downward near the knuckle. for installing it once the LCA was in place and a few threads were showing through the hole, I threaded on the bolt and cranked it down.
Old Oct 11, 2006
Civicman1988's Avatar
Do them yourself. They dont seem to hard i plan on doing mine in the spring
Old Oct 11, 2006
robbclark1's Avatar
The fronts NEED to be pressed in.
Spencer, so I can just drop the arm, take it someplace to get the new ones installed and just reinstall the arm with no problems with the ball joint?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
GolNat
Sep 10, 2015 08:25 PM
beachglass
May 22, 2015 09:59 PM
bryden13
May 18, 2015 12:22 PM
Dorval Andre
May 1, 2015 09:37 AM
