need help quick, strut bar install
Old Sep 22, 2006
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
it seems my strut tower is bent because of an accident.. i was able to align it by jacking up the car.. should i tighten it as i lower the car back down?... pics..
http://www.imagestation.com/picture/...c/ecdc3a98.jpg
http://www.imagestation.com/picture/...7/ecdc3a0e.jpg
sorry dont kno how to post images on this..
o btw its a neuspeed stru bar
Last edited by speedricerx; Sep 22, 2006 at 04:00 PM. Reason: Automerged Doublepost
Old Sep 22, 2006
robbclark1's Avatar
Retired suspension supermod.
Your bar isn't bent. The car generally hasn't be jacked for the bar to fit on. Some people don't have to jack it up, but most people do. Jack it up, tighten enough to hold into place, put car on ground, then torque to spec (33lbs).
Old Sep 22, 2006
i had to jack up the car.. in the first pic, the tower isnt bent?.. thanks
hmm.. i guess i never realized that the strut towers arent the same...
Last edited by speedricerx; Sep 22, 2006 at 04:25 PM. Reason: Automerged Doublepost
Old Sep 22, 2006
robbclark1's Avatar
It is kinda hard to tell. I would get it checked out to make sure there is no frame damage.
Old Sep 22, 2006
thanks... lowered the car back down and now gonna go for a test drive..it does look bent tho.. hmm
Old Sep 22, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
now that you mention it, that does look a bit off...i'd get it checked out...unless the accident was your fault....
Old Sep 22, 2006
seems ok after i drove it around awhile.. definitely noticed a difference..
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
andylao
Nov 4, 2001 01:19 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
