Tie bar comming off?
Old Sep 11, 2006
Darkfox3889's Avatar
Darkfox3889 is an unknown quantity at this point
Question Tie bar comming off?
Ok well while looking at the exhaust that someone put on my car after stealing my other one, I noticed it looked kinda like the rear tie bar is comming loose on the left side. What do you guys think?
Pics:
Old Sep 11, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
its not loose...that part is movable and don't worry that's fine. if your really worried then try to feel the bar if its loose
Old Sep 11, 2006
tuner04civic's Avatar
spell check pwns you
i dont have that tie down but from the looks of it, it should be tightened/adjusted. but i would see if it moves and check it all out.
Old Sep 11, 2006
rjngo's Avatar
yeah just re-tighten it to be safe
Old Sep 11, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
How hard is that to install, what do you do?
Old Sep 14, 2006
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
got the same bar, you should check it and retighten it every so often depending on how agressive and often you drive, but that part is a joint that is suposed to be able to move around a bit, just check it and retighten.
Old Sep 14, 2006
well i felt it, and it didnt wiggle around any so i guess its ok, do i just tighten the bolt under the joint to tighten it?
BootyDo
May 7, 2015 04:46 PM
Dorval Andre
May 1, 2015 09:37 AM
El_Spic
Apr 23, 2015 03:14 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
