My Uppermount Hits The Strut Why???
Old Jul 21, 2006
IrockCivics's Avatar
Since I had my rear camber kit installed my uppermount hits the strut when I hit bumps and when I go over a hill kind of fast but the worst is when I put people in the back... I hate it, **** sound so loud..... Now I cant have no1 in my back seat... Is there anyway this can be fixed? Do I need to take the camber off and get the oem ones? Please help.... Now I'm afraid to put a system because of this.... What should I do?
anyone?
Last edited by IrockCivics; Jul 21, 2006 at 08:16 AM. Reason: Automerged Doublepost
Old Jul 22, 2006
Old Jul 23, 2006
ryangt's Avatar
ryangt is an unknown quantity at this point
tell your friends to get off their asses and exercise
Old Aug 3, 2006
If I put on the stock camber will it still hit? This is driving me crazy....
Old Aug 3, 2006
ryangt's Avatar
try it and see, i dont see the camber making it bump. Bumping is usually cuz of the overloading of the car or the car being lowered too much
Old Aug 4, 2006
When I changed my wheels I checked it and the camber kit was hitting the inner body of the car... could that be it?
Old Aug 4, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
I don't see how the camber kit would hit. how low is your ride? can it be that you're tires are hitting the wheel well? or your struts might be blown and bottom out.
Old Aug 4, 2006
ryangt's Avatar
if you know whats hitting, why do you not address that problem and continue to post for no reason. If you know whats making noise, GO FIX IT stop looking for other problems if the problem is right in front of you. It basically sounds like you slammed your vic and are having clearance issues.
Dead blow hammer + tender civic sheet metal = extra clearance.
Old Aug 4, 2006
Zzyzx's Avatar
Autocross Junky
... I'm still trying to figure out whats hitting what...
the springs upper mount? (perch) and there are no struts on the rear of the car....
seriously, pictures of the parts would help greatly.. or at least a better description.
Old Aug 4, 2006
Diablo's Avatar
yes take a pic it will help others help you
Old Aug 4, 2006
ryangt's Avatar
definatly would be a useful visual aid. Can you see any fresh rub marks back there??? exposed metal ya know. That would be a good way to track down a mystery noise.
Old Aug 10, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
As I vaguely understand WTF is going on... mostly because I've heard of it... is the inner bushing housing of the camber arm is hitting the floor pan. Its because the housing on the camber arm is fatter than the OEM one, so there's much less clearance, and the car is lower (the arm angle is higher), so when you hit a bump, the arm hits the body. The fix is easy. Go under there, look where its rubbing at (very obvious, there won't be paint there anymore). Take a hammer, and make room for it.
Old Aug 10, 2006
Yup you are right.... I'm am going to try this later on..... Should I hammer it in alot?
1+ rep for u
Last edited by IrockCivics; Aug 10, 2006 at 04:02 PM. Reason: Automerged Doublepost
jdawgzcivic
17
Feb 1, 2020 04:16 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
Stock 99
Sep 5, 2015 06:06 AM
hatch90
Sep 3, 2015 08:45 AM
Amulon
Aug 18, 2015 11:03 AM
