has anyone had a problem getting the front SPC camber kit bolt in the front tokico blues?
the front left won't fit, but the bolt will fit in the front right. did i get a faulty shock?
what year is your car? if its 03+ than you didnt drill the hole big enough
you may just have to bore the hole like 2 mm... measure the two struts, and see if the holes are the same sizes!
it's an 01, so i shouldn't have to do any hole enlarging. the bolts fit perfectly in the right strut.
just take it out and drill it so it does fit
