Stripped Front Shock Tower Brass Screw
Old Jul 7, 2006
Robertsk8's Avatar
Robertsk8 is an unknown quantity at this point
Exclamation Stripped Front Shock Tower Brass Screw
A few of the front three shock tower brass screws on my civic 01 ex have been stripped. These 3x2 screws located in a set of 3 on each side of the car are attached to the shock tower assembly adn nuts. They are what are used to attach the front strut bar (for clarification). Well i have discovered a few of the screws (2 on the left side and 1 on the right) have been stripped. And now it is impossible to screw on the nuts. If you have any other better ideas I have decided i proabaly will have to replace them. Do you know where I could get some and also are they easy to remove have the spring has been removed for the shock tower assembly? Thanks ahead.
-Robert
Old Jul 7, 2006
PunkingCivic's Avatar
I need TP for my bunghole
Go here: http://www.hondaautomotiveparts.com/...artsSearch.jsp
Pop in all the ride info and BAM!
select FRONT SHOCK ABSORBER from the drop down menu,
look at the pic find the illustration number in the list below and see the price.
heres the pic for a 2001 ex coupe
Also, please fill out your profile so people can help you better.
You didn't list your year, body type, model and so.
As for the spings; go buy or rent a set of "coil spring compressors".
It will hold the spring compressed while you replace the spring hat.
Be sure to keep it aligned like this:
Old Jul 7, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
You have to rip the whole front suspension apart to get those out. If you're going to lower your car, you might as well do it now.
Old Jul 7, 2006
Robertsk8's Avatar
Thats exactly what i was thinking, proabaly go with some tein type s, the green ones, for a 1.25 drop without having to use install a new camber, Punkingcivic great post, check ur rep
Old Jul 7, 2006
thanks
and I corrected my typos too
Old Jul 7, 2006
Robertsk8's Avatar
delete
Old Jul 7, 2006
Originally Posted by Robertsk8
Hey about coil spring compressors, i know they are like clamps, would such stores like autozone have them and for about how much?
probibly $10.00 and up.
Depends on the contruction:
Here is a cheap one that gets the job done: http://www.harborfreight.com/cpi/cta...temnumber=3980
Here is an pricey one: $40.00: http://www.harborfreight.com/cpi/cta...emnumber=43753
or look here: http://da.harborfreight.com/cpisearc...SOR+&Submit=Go
Maryland store location: http://www.harborfreight.com/cpi/cta..._stores.taf#MD
Old Jul 7, 2006
Jap-Euro Fusion
Rent them from Autozone. $0.00 + refundable deposit.
Old Jul 7, 2006
Robertsk8's Avatar
well do the 6.99 or the cheap ones do the job?, if they do ill just buy them and let either dontate them to my club or uses them later on
Old Jul 8, 2006
I've used the those 6.99'ers on three cars and had no problem with them.
Just tighten evenly on each side.
No need to compress the spring too much.
Just enough to wiggle the spring hat and to keep it from flying at you when you take the nut off.
Old Jul 8, 2006
RHCP0801's Avatar
i never had to use spring compressors, lowered two cars without them...but if you do need one just rent it for free
Old Jul 14, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
I'm surprised Boiler didn't say that you should get a camber kit.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
vtec_concept
May 24, 2015 10:27 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
rhyno
Nov 27, 2001 10:07 PM
