how huch can i drop without problems
Old May 23, 2006
onesiccivic's Avatar
onesiccivic is an unknown quantity at this point
i want want to drop my 01 civic .. how far can i go without an aligment kit. if i have to get get one can i use the camber bolts.. i need to do this on the cheap per getting married but i also want to do this right .. if at all possible i want to go down at least 2-3 inches..
Old May 23, 2006
LXracer's Avatar
LXracer is an unknown quantity at this point
u should be good. you dont really "need" a camber kit. i dont have one on my vic. the thing u got to think about is if ur goin to put a body kit on lader. if u do what i did and lower ur civic then put a kit on down the road its goin to be super low wich i found out the hard way..and is the reasion i have to have 18 inch rims so i dont scrape lol. my car pulls a lil to the left but its nothin that bad. id just cut the rocker arms off and put it on the ground with bags JUSTTTT KIDDINGGG
Old May 24, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Yeah, "you don't really need a camber kit," you'll just need to change tires every six months.
OF COURSE YOU NEED A CAMBER KIT!!
Especially if you want to go 2-3 inches. You're gonna waste more money replacing tires than buying a camber kit for $150. Think about it, do it right the first time. LXracer's car pulls to the left because his car is not aligned correctly.
Old May 24, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
^^^^i Agree, Was Waiting For Some To Say That. Always Do Things Right The First Time. It Saves Money. Once You Drop It Any Highth, Change Rim Size, Or Get New Tires. Make Sure You Get A Camber Kit If You Drop It. Get An Alignment Aswell. Do Those And Youll Be Good. Dont Listen Lxracers Comment. He Still Has Alot To Learn
Old May 24, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
There's no such thing as cheap. Read all the threads stickied at the top
mikemc422
Aug 9, 2018 05:41 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
aZnVoYCe
Nov 11, 2001 10:43 PM
