loud clank noise from koni's
Old May 1, 2006
TWiSTEDKAOz's Avatar
TWiSTEDKAOz is an unknown quantity at this point
whenever im driving straight, theirs no noise.. but theres only noise whenever i turn the wheel or hit a bump.. I looked at it, and i used a jack on the drums and raised it, it makes a really loud pop noise, i'm not sure if its from the spring, or the shock, the back is fine tho. please help..
Old May 1, 2006
Al Gore FTW's Avatar
jdmtytedoridori
bottoming out, you're too low.
Old May 1, 2006
but even if im parked, and i turn the wheel, it still makes a very loud pop noise..
Old May 1, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Thats what im thinking.
Old May 1, 2006
btw i have ground controls + konis ..
Old May 1, 2006
jdmtytedoridori
mine did that on bumps a lot, i had the same setup. i dont know about when you are parked and turning though.
Old May 1, 2006
mndthegap1's Avatar
I have the exact same problem now with the exact same setup.
BUT it only happens from the passenger front, and its only if im driving really really slow or stopped and turn the wheel.
I searched found 1 thread about it, but there where so many different answers im not sure....
it is annoying, and if you figure out what it is ild love to know.
Old May 1, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
check the bottom bolt that holds the insert in place. it sounds like it maybe loose.
Old May 1, 2006
no its none of the bolts, i think its the control arm, something about that joint, but i contacted edward at true honda and he told me to lube it up.
i also found a few threads about it, it could be because i didnt properly index them, or something is loose. i am not sure, but my sounds are also coming from the passenger front.
Old May 6, 2006
Diablo's Avatar
If they are not indexed properly yes that can cause some noise when turning. Did you get the right size inserts? 01-and some 02 are 50mm and 03-05 are 55mm.
Old May 6, 2006
doubledeuce2k2's Avatar
could be the upper pillow mount. i have the noise on my driver side when i turn the wheel, have a friend sit in the car and turn the wheel. you'll see the mount turn when the pop happens.
this is caused by not lining up the mount when you reattach it after putting the springs/shocks together
Old May 8, 2006
AntiLoop's Avatar
AntiLoop will become famous soon enough
Having same prob... Passenger Front making sounds when i hit small bumps...
It made the sound with STOCK and still with my Tokico springs and struts.
Someone please figure it out the sound reallly bothers me.
cukaracha
Aug 27, 2015 02:02 AM
Hqly2001
Jul 25, 2015 05:32 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
1khilari
Jul 9, 2015 08:12 PM
