knockin springs???
Old Apr 26, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
knockin springs???
soo i got my car lowered..... looks crazy nice but when i hit bumps on my front driver said.... it knocks.. is it knockin against the fender or is it b.c my engine is hittin teh ground??? i dunno wat to tell the mechanicc thankss
Old Apr 26, 2006
burke420's Avatar
The World Is Yours!
well tell them that you probably got a blown strut, when i lowered on springs, i noticed a knock, then when i went to coilovers later....it was a blown strut, one month later I got KYB AGXs...that what you might need to invest in.... or some new bumpstops. those might be gone. 1.) check for the bumpstops. 2.) see if you're bouncing to try and see if you want some new struts/shocks 3.) make sure NOTHING is loose. springs, mounts, bolts, etc
Old Apr 27, 2006
djrabbi's Avatar
im not bouncin or anything its just when i hit lil a small bump that is underground it knocks, but when its above ground doesnt knock, its good to go... i just got my springs installed and they are blown already????? maybe something is loose
Old Apr 27, 2006
burke420's Avatar
The World Is Yours!
what springs do you have? stock shock are made for stock springs. it's alwasys better to swap them out with coilovers or springs. mine were blown at 40000 miles, but my warranty went bad at 36k, so i changed them after 15k miles later now i love the KYBs with Skunk2 coilovers. and what do you mean that is underground, it knocks.
Old Apr 28, 2006
bamb00's Avatar
underground probably means potholes and above ground probably means speed bumps
Old Apr 28, 2006
djrabbi's Avatar
like deep putholes. im thinkin its just hittin the bottom of the car...
Old Apr 28, 2006
PunkingCivic's Avatar
I need TP for my bunghole
how low is the drop?
Also they may have not trimmed down the bump stops.
This would give you that bottoming out sound.
also make sure that the four bolts are tight on the driver side strut.
If it is loose it make a knocking sound.
I speak from experiance on that.
Old Apr 28, 2006
djrabbi's Avatar
drop is 3 finger but hasnt settled..... well the passenger side doesnt knock so y would i need to trim the bump stop/?????? i dunno, but all the screws are tight... ill have my mechanic look at the bump stop
Old Apr 28, 2006
familycar's Avatar
i would say the problem is your spring isnt seated correctly allowing movement when the load is taken off the spring as it would be if the wheel moves down. try jacking hte car up take the wheel off and see if the spring is seated correctly on the shock. a lot of honda experience this problem with stock shocks and lowering springs. all the ones i have owned would come unseated on large holes. you can attribute it to the fact that the spring doesnt put as much tension on the shock to keep it in the correct position because of the decreased size in the spring itself.
Old Apr 28, 2006
djrabbi's Avatar
hmmm ill let someone at the nj meet look at it.....
Old Apr 28, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Originally Posted by djrabbi
..or is it b.c my engine is hittin the ground???
Old Apr 28, 2006
djrabbi's Avatar
Originally Posted by 03-Acura-1.7-EL
lol wats funny i was bein serious
Old Apr 28, 2006
pon55's Avatar
I'm a lot lower than you and I don't hit my engine
I'll look at it at the meet if you don't solve it first!
Old Apr 28, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
nope never hit my engine... I have like a 4 inch drop!
Old Apr 28, 2006
djrabbi's Avatar
yea ill have you look at it at teh meet. wont be drivin much since no more school soo yeaaa
Old Apr 28, 2006
02BLKCIVIC's Avatar
What kind of struts do you have??^^^
Old Apr 30, 2006
AntiLoop's Avatar
AntiLoop will become famous soon enough
ya if its stock struts, then its prolly struts... my stock struts blew 2 times.. junk
Old Apr 30, 2006
j.lu's Avatar
j.lu is an unknown quantity at this point
Any updates djrabbi ? noise is gone or what?
Old Apr 30, 2006
ragingSPAM's Avatar
I just burnt my tongue
when u turn the wheel do u hear clicking?...cuz the spring shock and upper mount might not be indexed right...that can cause a problem of knocking noises or clicking...it happened to me first when i was putting my stock strut back together...it didnt get indexed right so when i turned the wheel while the car was on jack stands it would pop...but now i've taken the suspension appart so many times that i dont have to worry about not lining it up
Old Apr 30, 2006
djrabbi's Avatar
when i hit a small pot hole it knocks still.... i dunno wats wrong still
Old Apr 30, 2006
j.lu's Avatar
I have the same problem (on the driver side ).Is just when I hit small potholes.I replaced everything bearings,mount, strut....and the noise still there.Indexed 3 times.Now what?
Old May 1, 2006
familycar's Avatar
try your ball joints
Old May 1, 2006
j.lu's Avatar
Ball joints fine
I just drove the car around the block and the noise is gone.
What I did?
Plastic tube around the springs rofl:
Old May 7, 2006
AntiLoop's Avatar
Any fix yet ? I have a small knocking sound when i turn left and hit small bumps.. It happened with stock springs and struts, and still have the sound with my aftermarket Tokico springs and struts.
I would really like to know the problem to this sound, looks like im not the only one. I went to Honda and they didn't know they said it migh tbe struts.. clearly that wasnt it, after I got mine replaced.
Someone figure this out please !!!
Old May 9, 2006
djrabbi's Avatar
Originally Posted by j.lu
Ball joints fine
What I did?
wait wat u mean plastic tube.... like u put inside the spring or like around the whole spring
Old May 9, 2006
familycar's Avatar
plastic tube around the shock, that cant be the noise your describing its not thick enough plastic to make that sound, i know what you mean because i believe i have the same problem. i just havent bothered to tear into it yet.
Old May 28, 2006
djrabbi's Avatar
sooo my driver side knockin is gettin louder and more eaiser to knock...... i dunno wtf to do... my mechanic said nuttin looks wrong wit it cause if i tell them to look at teh strut and take it apart, he will charge me...... i dunno i think i never shouldve gotten it lowered now
Old May 30, 2006
familycar's Avatar
no man the problem is probably because the mechanic didnt index the shocks correctly
Old May 31, 2006
djrabbi's Avatar
the mechanic didnt do them, eddie did..... sooo i guess i gotta get em fixed
Old May 31, 2006
RHCP0801's Avatar
thats because eddie sucks
