4/18*UPDATED W/PICS*Rear strut assembly...???
Old Apr 15, 2006
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Question 4/18*UPDATED W/PICS*Rear strut assembly...???
I got my Tokico HPs and Eibach Sportlines assembled today. When I got the rears put together the strut cap (piece that mounts in the trunk) looked tilted to one side. Is it just because the springs are new and haven't settled or are they assembled wrong. Everything is lined up just how it came apart. Any input would be greatly appreciated.
PICS:
Old Apr 15, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
take a picture
Old Apr 16, 2006
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Yea if you could take a pic so we could see it. It sounds as if the spring is not setted in the mounting plate correctly.
-Jay
Old Apr 16, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Picture is worth a 1000 words. ANd would help a lot.
Old Apr 18, 2006
Im a little stumped here.. Looks as if you didnt get something back together right. But not sure.
Old Apr 18, 2006
gipperkid's Avatar
I think it's because the springs haven't settled. I marked the parts during disassembly and lined the marks back when I reassembled the struts. I just want to be sure that nothing is screwed up.
Old Apr 18, 2006
eye_see_you's Avatar
let the devil out
I had the same setup it should be level maybe you did not get the notch and the spring right
Old Apr 18, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Well the top of that mount is basically two rubber bushings with a metal bushing in the middle, sooo, it's possible that the bushings aren't pushed together completely. It's also possible that everything will straighten out after it's installed on the car BUT I would definitly check out the bushings first.
Old Apr 19, 2006
redsled01's Avatar
redsled01 is an unknown quantity at this point
i havethe same struts but i got the neuspeed springs, i get a lot of popping noise now
Old Apr 19, 2006
gipperkid's Avatar
I checked those two rubber bushings in the top plate, but I will double check them. But I still think it is because the springs aren't settled. I am going to remove my factory struts soon and I will compare the factory rears to my new setup. It's not like it takes much to take the rears apart if I have to. Also I know with Eibach springs, they say not to fit the spring snug against the step on the lower housing, but leavehttp://hondatuningmagazine.com/tech/...on_19_zoom.jpg a little extra room (quoted form hondatuningmagazine.com). But on the rears does this need done as well???
Old Apr 19, 2006
blouisgod's Avatar
Life Begins > 6800rpms
they look assembled right. i think they look funny because they arent under load.
Old Apr 20, 2006
YSIDRAG's Avatar
Those look fine put them on the car.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
