Sway bar
Old Mar 21, 2006
deadbob2000's Avatar
deadbob2000 is an unknown quantity at this point
Sway bar
Hey all, I need some help. I recently took off my front sway bar to replace it with my new progress front sway bar. We ran into trouble with then end links and were forced to put the oem sway bar back on due to time restraints. Now when im driving there is a popping or cracking noise coming from either the end links or the bushing on the sway bar. Does anyone know what that might be? Also doe anyone know how to get those end link bolts to loosen? thanks
Old Mar 21, 2006
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Make sure it's all tight and you didn't lose any bolts like me
For the other part i forgot how to take off the endlink
Edit: Future use the search and lookin DIY on main page on the right. Heres a freebe
http://www.7thgencivic.com/forums/sh...d.php?t=155274
Old Mar 25, 2006
gelshmoff's Avatar
gelshmoff is an unknown quantity at this point
the popping noise, i think, is the endlink moving to its extents. I got a similar sound after I installed my progress front sway bar. i haven't had any problems with it, though.
the endlink bolts are a biotch to get off. hose it down with wd40 and let it sit for 15-20 minutes. wipe it off with a rag and repeat if necessary. then use an alan wrench on the end while you loosen the bolt.
you should consider new/aftermarket endlinks. mine were pretty messed up after i got them off. good luck
Old May 29, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
i just installed an rsx rear sway bar on my car and it makes some popping and squeeking sound when i turn slightly fast and sometimes even just normal driving...i did tightened it as hard as i can.
Old May 29, 2006
TeLLy's Avatar
Yes, it's an Acura EL
rjngo, are you using the stock brackets or polyurethane? Have you checked to make sure you installed it right side up? Doublecheck each end of each endlink. If you're really stuck, post up a picture of the bar as it's installed so people can check.
Old May 29, 2006
rjngo's Avatar
i used the rsx bushings with stock brackets to hold it. i'm 100% sure i installed it right because if you install it the wrong way - it would fit!
i'll post pics later on
Old May 30, 2006
TeLLy's Avatar
Trust me it'll fit installed upside down...but it'll smack control arm constantly.
Old May 31, 2006
burke420's Avatar
The World Is Yours!
is your car lowered, or do you have stock endlinks,
1.) if you lower your car, then the endlinks might hit the piece of metal near the endlink, bend the metal inward, and then try.
2.) you might've broken your stock endlink!
3.) if it's broken but the new Hotchkis endlinks, i got mine yesterday, theyre on stand by for install...
Old Jun 2, 2006
dlin's Avatar
dlin is an unknown quantity at this point
where can you buy the hotchkis end links? (or grey's)
Old Jun 2, 2006
imsonastie's Avatar
imsonastie is an unknown quantity at this point
i used r/c car shock oil to get my bolts off for the endlinks, you might need an allen key for the bolt to hold it in place while you unscrew the nut from the threads, the key goes in at the tip of the threaded part, you keep it stationary while you unscrew the bolt, might want to wear gloves.
Old Jun 5, 2006
rjngo's Avatar
this is my installed rsx rear sway bar
what do you guys think? did i installed in properly or what?
Old Jun 5, 2006
burke420's Avatar
The World Is Yours!
http://www.nopi.com
2002 Acura Rsx, for car model i bought for.
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
