Need Opinion on Springs
Old Feb 24, 2006
bigmurr's Avatar
Downed but not for good
bigmurr will become famous soon enoughbigmurr will become famous soon enough
OK just got my taxes in and I have a couple hundred to spend on springs.
I would like to have a medium drop just about 1.0" to 1.5" so I can keep my OEM shocks/struts.
So I have two options:
Eibach Sportline (which I know are good) $230.00
http://www.dezod.com/pd_eibach_sportline.cfm
or
H&R Sport Springs (which are about $80 cheaper) $154.00
http://www.dezod.com/pd_hr_sport_springscivic.cfm
And what exactly is the drop on those Sportline because I hear it being 2.0" and 1.5" and I dont know what to trust. Thanks guys for your help.
Old Feb 24, 2006
Gabe Niemeyer's Avatar
Gabe Niemeyer is an unknown quantity at this point
get the eibachs
Old Feb 24, 2006
bigmurr's Avatar
I just read somewhere that the springs also wear in so that 1.5 eibach would lower even more. Would that put too much stress on my shocks if it does wear in? Or am I ok to go with eibach?
Old Feb 24, 2006
Civicman1988's Avatar
eibachs are the best
Old Feb 24, 2006
bigmurr's Avatar
well I just found an Ebay auction for some H&R springs for 70
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8040041581
is that a good buy? personally I think it's a little high for 10,000 miles but maybe I'm wrong.
Old Feb 24, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
sportlines are 2. pro kit is 1. so you are lookin for a eibach pro kit for 1 inch.
Old Feb 24, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
I have progress and loved them since i baught them. But i Talked the retard i baught them off of to sell them for 50.00.
Old Feb 24, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
H&R will blow your stock struts i had a set on stock struts and they started to leak after a couple of weeks. Eibach are better quality springs. I don't know if the struts will last you tho.
Old Feb 24, 2006
Slow Gold's Avatar
If you lower you car 2" you will need a camber kit and struts in the future this is a given...
Old Feb 24, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
sportlines are not 2" more like 1 5/8", just over what they call 1.4"
Old Feb 24, 2006
Diablo's Avatar
Thats correct, camber kit is a must if you want to save your tires. with 1.5 drop or more
Old Feb 24, 2006
Slow Gold's Avatar
What im mearly saying is dont lower your car and think that stock struts will last longer than a year.
Old Feb 24, 2006
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Go with Eibach. Get some Tokico Blues as well.
Old Feb 24, 2006
bigmurr's Avatar
So you're saying that even if the H&R springs lower your car about 1.3" like the link I have up there, it will still blow my stock struts. I thought if it passes a 1.5" drop it will mess up your stock struts?
if thats the case I guess I'll stick with prokit and only do an inch.
Old Feb 24, 2006
obliviot's Avatar
obliviot is an unknown quantity at this point
If you hit a bump in the road and get the travel out of your struts, yes they will blow.
The design of the stock strut is only allows for the travel on a stock spring.
Once lowered, the compression ratio of the stock strut is not a match for the extra 1" - 2" of travel that is gained with the springs. The struts may last a day, a week or even a month or two depending on how you drive and what the roads are like where you drive.
I have the Eibach sportlines, and now I need the tokico blues. The stock struts are long gone. But it handles really well in smooth curves.
Oh, you will need a camber kit if you plan on keeping tires on your car longer than 10K miles. There's my 2 cents.
My rear springs and camber kit are going on very soon. Weather permitting.
Old Feb 24, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
eibachs all the way, the make very reliable, accurate and consistant springs. i have a set of sport lines on my car and it gives it a nice drop and isnt too stiff. and dont worry too much about scraping and stuff, it's not that bad. prokits are good too, but i just found that sportlines are so much nicer. it has a 2 finger gap front and back. i've tracked with them as well and got little body roll, compared to some cars that is. and i've been running on stock shocks for a month as so far, it still nice and strudy, no boicing and crap, i'm sure it will hold up just fine for a while, just so long as you dont abuse the suspension by making fast 25mph right turns into a driveway or somthing.... as for camber.... no matter what springs you get i would suggest getting camber kits, but it is not totally nessesary. some of the other peoples comments are a bit over exagerated, but personnally i find it crucial for my needs
Old Feb 24, 2006
MajinB's Avatar
um, lets be realistic, if i go lets say, 20mph over a speed bump, my **** will blow. if you baby your car like i do, its WAY less likely. thats just the truth. idk bout you guys, but i take FOREVER to go over speed bumps on stock stuff. yes stock stuff. won't be stock soon but i still baby my car. just be careful. yes potholes exist and stuff happens but you know, be careful
Old Feb 25, 2006
shj503's Avatar
shj503 is an unknown quantity at this point
I just think drop with H&R springs look ideal
but that's just me
Old Feb 26, 2006
vtec407's Avatar
vtec407 will become famous soon enoughvtec407 will become famous soon enough
I myself am debating between Sportlines or Neuspeed Sport, both using Koni Yellows.
skeener51
Oct 1, 2015 05:56 PM
Luluharp
Sep 27, 2015 11:56 AM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
