coilvers on 03+??
Old Jan 23, 2006
sifusexc's Avatar
sifusexc is an unknown quantity at this point
coilvers on 03+??
I have done my research, and the only straight answer I could find is Robbclark1's FAQ. Konis fit on the 03's bc of the 16mm option.
The only full coilover I could find for the 16mm bolt are the progress cs1. Any of you guys know if any other manufacture makes a coilover kit for the 03 up? I really do not want to drill out the 14mm to 16mm, because if something happens and the set is not drilled out right, then its all on my ***. Thanks for the input guys.
Old Jan 23, 2006
fi dx's Avatar
fi dx is an unknown quantity at this point
my progress coilovers had to be drilled out to 16mm
Old Jan 23, 2006
D17Civic's Avatar
D17Civic is an unknown quantity at this point
i got tein basics on my 05
Old Jan 24, 2006
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
Konis have nothing to do with the adjustable 16mm bolt. the bolt is part of the strut where as the koni shock is...well just a shock. the shock is an insert into the housing of the strut, once you gut the strut of its previous shock. if you want coilovers just get Konis+Ground Controls. just need to measure the valve size on your OEM strut/shock to know wether or not you need 50mm or 55mm koni shocks up front.
Old Jan 24, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
*cough* EP3 kit *cough*
Old Jan 24, 2006
sifusexc's Avatar
simple as that. thanks boilermaker
Old Jan 25, 2006
03civda's Avatar
03civda is an unknown quantity at this point
KW Coilovers have the option of either 14mm or 16mm
sharper
Mar 26, 2005 10:21 AM
thefivespeeder
Mar 25, 2005 11:57 AM
D17thgen
Mar 19, 2005 08:47 PM
ravolutionazx
Feb 16, 2005 02:10 PM
jttegx
Feb 7, 2005 04:10 PM
