Acura EL 03+ gauges
Old Mar 24, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Acura EL 03+ gauges
Ok, i have an 01 5speed coupe, and i need new gauges, i was thinking about going to the 03+ civic ones but now am thinking, how different would the install be if i got a 03+ Acura EL cluster? does it matter if the Acura has a permium package or not?
Old Mar 25, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
either way you are going to have to cut the OEM plugs off your stock harness, get the plugs from the harness on the 03 EL or civic, and splice your wires into them. The plugs are different, and the wire colors are as well, so you will need wiring guides.
Old Mar 25, 2005
you dont have cut off the plugs, you just pull the pins out, just like if it were a 01 to 03 conversion
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
