neuspeed springs?
Old Jan 22, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
neuspeed springs?
When I got my springs and I started to install them i realized that the spring was bigger then the stock spring mount on the top in the fronts? Now it binds a twists because it is not fully compressed, so my question is:
Is there a peice that was supposed to come with the springs to widen the top mounting location?
Old Jan 23, 2006
Dondie's Avatar
Dondie is an unknown quantity at this point
The springs should perfectly mount on the stock mount. Used to have neuspeeds no problems with installation.
Old Jan 23, 2006
AlienX's Avatar
AlienX will become famous soon enough
^^ same, just like stock replacement.. pull out, put in.. you dont even need a compressor to reinstall the mount because the spring was soo much smaller in height
Old Jan 23, 2006
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Do you have all the parts in this illustration? The springs should fit fine with all the factory upper mount parts in place.
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
Old Jan 23, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
make sure you put the flat end up. some people here will tell you it goes down but i go my info from the people at neuspeed.
Old Jan 23, 2006
jeffsta17's Avatar
nevermind...
Old Jan 23, 2006
jeffsta17's Avatar
Thanks guys, it turns out that the guys that installed my old springs the first time took all the upper mounts off, I didnt realize that so now these springs were not going on...thanks again for all your help.
Old Jan 23, 2006
Diablo's Avatar
Originally Posted by Jeffsta17
The spring is twice the width of the stock spring... its weird
It sounds to me like they sent you the wrong set of springs. who did you buy them from?
Old Jan 24, 2006
Diablo's Avatar
Check the part number. if you have the sport springs you should have this part #55.20.62 or The Race springs are the 55.20.68. if you don't have any of these part numbers then you have the wrong ones.
Old Jan 25, 2006
jeffsta17's Avatar
Thanks man i ended up figuring it out, place that installed my original springs got rid of the upper mounts.
Old Jan 27, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
if i get a set of neuspeed springs, what the best shocks to replace stock with, and hwo much am i lookin at for both?
Old Jan 27, 2006
Diablo's Avatar
If you are looking to buy springs and shocks, you should consider getting full coilover instead it might be sheaper. most shoks wont last with a drop. unless you get a set of Koni yellow specially made for the drop you want. you would have to contac Koni and let them know what your plans are. I say get full coilover.
Old Jan 28, 2006
Ashhole's Avatar
i dont really want the coilovers cause ill never adjust them. was lookin at getting a set of tockico(sp) shocks to go wtih the springs
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
