Rubber Spring Seat Thingies
Old Jan 10, 2006
AzNmiKex215's Avatar
2k1civic.com O. G.
My springs are sqeaking like hell in the rear, the front driver also sticks and makes a "bong bong bong" noise when turning.
All of the rubber peices that the springs sit on have ripped and fell off.
Where do i get new ones? What are they technically called? I need to buy a full set of 8, with inner diameters of 2.5 inches.
Thanks!
Old Jan 11, 2006
mmm2donuts's Avatar
mmm2donuts is an unknown quantity at this point
bump for having the same exact problem! im on tein basics btw.
Old Jan 11, 2006
ragingSPAM's Avatar
I just burnt my tongue
did u index the shocks right?...hmm www.hondaautomotiveparts.com will have them
Old Jan 11, 2006
2k1civic.com O. G.
Its not oem parts that I need. I have D2 racing full coils. I need the rubber end peices that eliminate metal to metal contact between the bottom of the spring and the perch, as wel as the top of the spring and the mount.
2.5 inch inner diameter. I think i may try to call eibach.
Old Jan 11, 2006
2k1civic.com O. G.
i noticed on non full coilovers like the nuespeed, there isnt any rubber piece at the bottom under the spring where it touches the metal locking perches.
Does that cause metal to metal noises?
Can those metal peices touching together make squeaks? Or does squeaks imply that rubber is involved?
My rear bushings are also shot to tell, Is that the cuase of my rear squeaking?
Old Jan 11, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I've honestly never seen a set of coilovers that has an isolator. My JICs have a little metal slide ring between the collar and the spring, but its just a little aluminum sheet. Teins don't appear to have anything, GCs don't either.
I don't know what this rubber thing is, but I think you can stand to lose it.
Try a little lithium grease on the spring ends, or just clean stuff up. An abundance of crap accumulating on the seat will cause the springs to rust a little, which will lead to sticking and noises.
Old Jan 11, 2006
2k1civic.com O. G.
Now that i think about it, i probably can rip it off with no problem. Im pretty sure the rubber on the top of the spring is causing the spring to stick to the mount while turning, making that bing bing metal noise.
I am pretty sure the Tein basic comes with a tiny little black rubber spring seat piece. I installe a set for a friend a little while ago.
Here is the piece im taking about. I will remove all of them as long as it doesnt cuase metal to metal clanking noises, it probably wont as long as the spring is preloaded right?
Old Jan 11, 2006
Jap-Euro Fusion
You can stand to lose those without any issues.
they're probably just there to save the anodized finish.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
