Few Questions *HELP*
Old Jan 1, 2006
GACivic's Avatar
GACivic is an unknown quantity at this point
Ok. I had my car lowered, on Eibach Sportlines, and SPC Camber kit. Well the first "problem" is that the front looks a good bit lower than the back. I asked the guy who lowered it and he said after it's driven around a while, the springs will settle and it'll be lower. Is this true?
Second question. Something about the car being lowered is messed up and he is trying to fix it. Whenever you turn it makes this horrible clicking noise. But when the car is up in the air, it doesn't make the noise. He said it would be like some kinda rods or something, I don't really remember.. Any idea?
Old Jan 1, 2006
it will look different a month later. let it settle. my sedan is actually lower in back. did he align the arrows on the shocks when putting spring back? i can't explain too well. most of the lowered guys here have some sort of noise problem with clunking and such.
Old Jan 1, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
read #19 on hiere http://www.hondatuningmagazine.com/t...ht_suspension/ this can be the cause of the problem you are talking about
Old Jan 1, 2006
GACivic's Avatar
No its not like a few clicks its horrible, when you turn the wheel at all its like bump bump bump bump.
Old Jan 1, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
Ya just let the car settle for a while and see how everything goes but i get a clicking noise every now and then...
Old Jan 1, 2006
Diablo's Avatar
when i first lowered mine it was making a pop sound when i turn the wheel all the way but after a wile it stoped. it could be the bearings or he just didnt align the top cap the right way.
Old Jan 1, 2006
GACivic's Avatar
He's puttin the car back on the rack and tryin 2 fix it.
Old Jan 1, 2006
klectic's Avatar
klectic has a spectacular aura aboutklectic has a spectacular aura aboutklectic has a spectacular aura about
im having the same problem but on progress sport springs.
my front passanger clunks a little on bumps and such, but not when turning. although i never had any problems with my h&r
and the springs will settle still, but for how long, i've been trying to do a search..many people say it varies ???
a few days, a week or so, a month (as someone posted earlier)
so that i'm not to sure on either
Old Jan 2, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Struts are not indexed and it is a problem to all noises from the front after sprins/coils insall...
Search for strut indexing or our civics and all yor problems will go away.
Any unnessessary noise that you hear indicates a problem. Indexing your struts is a solution.
zack22490
Apr 29, 2015 03:17 PM
superstanko
Apr 28, 2015 04:38 AM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
klam
Nov 16, 2001 03:36 PM
