Noob rear strut bar problem...did a search
Old Dec 15, 2005
Framet's Avatar
Framet is an unknown quantity at this point
Hi I have a 03 coupe Ex and I am having a hard time installing the rear strut bar. I have a generic strut bar and I just can't find a way to install the bar. When I drop the rear seat and open a plastic piece I barely see the strut tower. It looks like to installs the strut tower I might have to remove the seats. Hopefully you guys will be able to help. Thank you
Old Dec 15, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
no you dont have to, the carpet in the trunk covers the towers themselves, i dont have a pic, but the best way i candescribe where they're at is on the front of the rear wheel well, hope u figure it out!
Old Dec 15, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
6" socket extension through the hole where the plastic cover is. Thats why the hole is there.
Old Dec 15, 2005
Framet's Avatar
K what do I do with a 6" extension in that hole? Do I look for something in perticular??
Old Dec 15, 2005
booba5185's Avatar
there's a 14mm nut that is hidden and can only be reached through that hole, the other 2 nuts are accessable by the trunk...
Old Dec 15, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
^^ i have pulled mine off 3 times and never knew about the covers lol. Like what was said just go all the way in your trunk(corners) and pull the little piece of carpet back ohh ya and make sure your bar is nice and loose before putting it on you may need to adjust it a few times. I did mine with out pulling any seats. Good luck.
Old Dec 15, 2005
booba5185's Avatar
here's the hole to get through to the hidden nut (backseat):
and the other 2 nuts:
Old Dec 15, 2005
cg95660's Avatar
There is only two nuts right? At leats mine only has 2 (2002) and they where both through the trunk.
Edit dam it i had to use a swivel lol!
Old Dec 15, 2005
Framet's Avatar
K the first picture I follow, but then how do u get to the second picture. Sorry If I am just slow, where are the two bolts located. Thank you
Old Dec 15, 2005
booba5185's Avatar
in the trunk, under neath the carpet... basically on the otherside of the first picture....
Old Dec 15, 2005
Jap-Euro Fusion
Oh jeez.
First question... you understand what a wrench is right?
If yes, continue.
Pull the carpet back, put the seats down, pull the cover plate.
14mm deep well, undo the inner bolt (the one you can get a wrench on from the trunk) then go through the hole in the seat panel with a 6" extension on the 14mm deep well socket. Undo the other one. Install the end plate w/o the bar, do not tighten the nuts all the way.
Repeat for other side.
THEN bolt the bar between the end plates. Tighten the nuts on the bar ends.
THEN torque the bolts on the shock towers to 45 lb-ft.
It can't be spelled out anymore.
If you didn't understand that, just give up, send the bar back (cuz it isn't going to do anything anyways) and put the trunk back together.
Old Dec 15, 2005
Framet's Avatar
Thanx for the help guys. To the few that got angry sorry for been a noob.
Old Dec 15, 2005
riced's Avatar
riced will become famous soon enoughriced will become famous soon enough
lol more and more people are putting "did a search" in their thread, because they know the "consequence"..
Old Dec 15, 2005
Jap-Euro Fusion
^^^ they can put it there, but its pretty obvious when they don't.
Same thing still happens.
SugarRay
Dec 13, 2001 09:58 AM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
CapYoda
Nov 11, 2001 05:17 PM
