oem front sway
Old Dec 10, 2005
CrazyAznRacer's Avatar
CrazyAznRacer is an unknown quantity at this point
oem front sway
i wanna get the 01-02 front sway bar (25.4mm) but i didn't know if i need any bushings or anything to make it work with my car (05 civic LX sedan). Would this bar be a direct bolt on?......any modding needed?...any feedback is appreciated thanks
Old Dec 11, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
you need the 25.4 mm bushings for it. you can't use the stock ones, but it bolts right on.
Old Dec 11, 2005
Civicman1988's Avatar
I have an 02 civic EX sedan is my front sway bar 25.4mm and where can we get bushings that big?
Old Dec 11, 2005
eye_see_you's Avatar
let the devil out
neuspeed has fron bushings that I put on my EX for 20.00 also I beleive energy suspension makes some
Old Dec 11, 2005
so i need to get 25.4mm bushings for the front.......also i want to know if the rsx rear sway bar is a direct bolt on....any bushings needed for that?....thanks guys for the feedback
Old Dec 11, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
You will need bushings but usually when you buy the rsx bar its comes with bushings. Just make sure to ask the person you are buying it from.
Old Dec 11, 2005
robbclark1's Avatar
Retired suspension supermod.
jegs sells ES universal bushings
or get OEM Honda ones.
RSX is direct bolt on for all EXs, 02+ LX, and no DX or HX. You need 19mm bushings.
Old Dec 11, 2005
so since i have a 05 lx sedan i would not require new bushings for the rsx rear sway bar?
Old Dec 11, 2005
robbclark1's Avatar
You have a 13mm sway bar. RSX bar is 19mm. 13mm does not equal 19mm so yes you need new bushings.
Old Dec 11, 2005
alright will the rsx bushings fit on my car? or where can i find 19mm bushings?
Old Dec 11, 2005
hawkz99's Avatar
hawkz99 is an unknown quantity at this point
As the guy above says, make sure you get them from the seller of your sway bar. If you haven't bought it yet, you can probably get the bar & bushings from clubrsx.com That's where I got my REAR sway bar (bushings included).
Old Dec 11, 2005
robbclark1's Avatar
come on man...read the posts!
1) the seller of the bar
2) OEM - honda/acura dealer (rubber)
3) Jegs - ES poly universal sway bushings
Old Dec 11, 2005
ok i got it thanks everyone ok to lock now!
Old Dec 12, 2005
Jap-Euro Fusion
For crying out loud. Just search.
Old Dec 14, 2005
FALKEN's Avatar
Civicforums Junkie
i bought the bushings for the 2005 TSX (25.4mm) from www.summitracing.com
-ENERGY SUSPENSION-
25.4mm
polyurethene
red
edspyhill09
Jun 12, 2016 02:45 PM
Makeice3498
Jul 2, 2015 11:13 AM
stryder12
Jun 30, 2015 08:33 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
