Ground control lowering springs with stock struts
Old Nov 12, 2005
h2oskier's Avatar
h2oskier is an unknown quantity at this point
I just bought a 2001 Civic that had ground control lowering springs on it with the stock struts on both the front and rear. The ride is horrible, bottoms out makes a springy noise in the front and a banging noise in the back all the time and is real bouncy. I just bought some stock springs from someone on this forum, I put the back ones on and now the car looks stupid with my 17" wheels and the rear end so high. The ride improved and rear noise is gone but it looks dumb. My question is, were the ground control lowering springs designed for stock struts? Will my ride improve with different struts again both front and rear and keeping the ground control setup. I don't want a horrible stiff ride so what are your recomendations for keeping it low and changing out the struts and getting the best ride possible. I have 17" rims with 205/40R17 Yokohama AS430 tires. Any help and or advice would be extremly helpfull to me.
Old Nov 12, 2005
ragingSPAM's Avatar
I just burnt my tongue
your shocks are blown...u need new shocks...i suggest getting some tokicos or if u have money some koni yellows and using the ground control springs with them...using stock shocks and lowering springs will blow them out in a year or so
Old Nov 12, 2005
h2oskier's Avatar
Please desribe the ride of the two shocks that you recomended. I am looking for the most comfortable ride possible.
Old Nov 12, 2005
CenZ's Avatar
PWIT
i dont think tokico blues can handle GC, you need Koni Yellows. from what i have read on here they are the best with GC. GC are way to drastic of a drop for the stock shocks. the highest they go are 2.5" which is way past what the stock shocks can handle. they can do like 1.75" at most without any problems. if you are slammed on GC 2.75"~3.0" im supprised they didnt blow out right away. Koni Yellows are prolly the way to go. if you look hard enough you can prolly find a set for around $450ish which aint bad of a price.
Old Nov 12, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Yellows are the only thing I'd trust with GCs.
Any shock will work better than a stock one
Tokicos are softer than Konis.
Old Nov 12, 2005
h2oskier's Avatar
Where is the best place to purchase the Koni's?
Old Nov 12, 2005
Jap-Euro Fusion
Pick a place, you get the same shocks no matter what.
Try the vendors on this forum for starters.
This isn't pricewatch. Do some work for yourself and find the best price.
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
vtec_concept
May 24, 2015 10:27 AM
1028CiViC
Nov 24, 2001 02:14 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
JumpingBean
Nov 17, 2001 04:53 PM
